b18a engine swap problems!!!
Old Aug 10, 2005 | 10:23 PM
mauibuilt's Avatar
Default b18a engine swap problems!!!
the swap is all done b18a into 89 crx si, converted to obd 1 using boomslang harness. cut of resistor and soldered all wires together, obd 1 distributor and injectors. go to start the thing and idles perfect, BUT WHEN I REV IT IT GOES TO ABOUT 1000-1500 AND DROPS DOWN TO 500 AND REPEATS!!! over and over and over!!!! i threw a code 14 which is IAC VALVE could this be the problem or what else could it be!!!! im lost any one else with the same problems. so close i just want to drive my crx
Old Aug 10, 2005 | 11:12 PM
EFRue57's Avatar
Default Re: b18a engine swap problems!!! (mauibuilt)
yeah......that definately could be a problem. sounds like you either need to change it out or try to find a vacuum leak somewhere.
Old Aug 11, 2005 | 07:49 AM
mauibuilt's Avatar
Default Re: b18a engine swap problems!!! (EFRue57)
im running 19 on my vaccuum gauge which is normal so thats out.
Old Aug 11, 2005 | 03:16 PM
b18apwr's Avatar
IACV and IAT plugs switched?
Old Aug 11, 2005 | 11:56 PM
mauibuilt's Avatar
Default Re: b18a engine swap problems!!! (b18apwr)
another thing when i remove my tps i can rev it to 2500-3000 grand and then it fluctuates 2500-3000 over and over maybe its that!!! thing i pulled the engine from my 92 integra and everything worked perfect...
lefebvre
Feb 4, 2010 07:24 AM
civhatch90
27
Nov 29, 2006 09:05 AM
RotiEatter
11
Oct 16, 2003 07:37 PM
speedracer33
May 24, 2001 07:53 PM
