Suspension & Brakes Theory, alignment, spring rates....
Bouncy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 10, 2005 | 08:34 PM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
Default Bouncy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Okay here is the deal
I have a 94 DX hatch with (ITR rear LCA's) on OmniPower ITR Sports....Now my car is bouncy its pretty dropped wheel tuck....would that have anything to do with the ride being bouncy?
Old Aug 10, 2005 | 09:03 PM
chrisw85's Avatar
Sure would. If you are too low, you will bounce. Lots of things could be causing it, coil bind, internal shock bottoming out, upper control arm binding, etc.
How low is low? How much of your wheels are tucked?
Old Aug 10, 2005 | 09:31 PM
hawjboi's Avatar
Default Re: Bouncy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (MR.RED'89)
i dont know...with all these problems with omni you should take them off and visually inspect them...they could be blown...
Old Aug 10, 2005 | 09:33 PM
^Sammy]!.'s Avatar
Default Re: Bouncy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (hawjboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hawjboi &raquo;</TD></TR><TR><TD CLASS="quote">i dont know...with all these problems with omni you should take them off and visually inspect them...they could be blown...</TD></TR></TABLE>
Well I have the new collars to put on so im gonna check them out tomorrow while i swap out the collars
Old Aug 10, 2005 | 09:46 PM
EK k kay's Avatar
High spring rate coilovers + slammed = don't expect it to ride smooth. Even if it was not slammed it'd probably still be bouncy on city streets because they are pretty high rates.
FuKThEiVeS
Nov 4, 2006 06:31 PM
lastlude2k1se
Feb 13, 2005 12:13 AM
black92si
Jul 25, 2003 08:09 AM
typeee
May 6, 2003 10:48 AM
