Wider is better!?!?!
Old Feb 21, 2002 | 06:22 PM
EKhatch's Avatar
Default Wider is better!?!?!
Hey guys, I need a little help. I own a 1993 F2 and desperatly want to fit up a wider rear rim. I found a 900RR rear rim for sale on e-bay but I am not sure if it will fit? Got any ideas?
Thanks
Also, if any one knows who makes some ride hight adjusters for my bike please let me know, it seems they are hard to find unless you own a GSXR!
Old Feb 21, 2002 | 06:43 PM
BDiddy's Avatar
Default Re: Wider is better!?!?! (EKhatch)
why do you want a wider rim?
Old Feb 21, 2002 | 08:37 PM
EKhatch's Avatar
Default Re: Wider is better!?!?! (B-DIDDYR2K)
So that I can put a wider tire on it.
Old Feb 21, 2002 | 09:01 PM
BDiddy's Avatar
for what reason?
Old Feb 22, 2002 | 05:19 AM
PM-Performance's Avatar
i would assume for more aggressive stance and better handling.
i wanted to too on my katana , the rear tire is only a 130. its hella skinny .
i talked to some other guys and they said it will handle like *** with wider tires.
they said the handling is much more precise and quicked with the skinnier tires. ???
i dont now but it stil looks like a ***** bike with these tires.
im getting a set of avons soon and dont know what size i wanna get yet
Old Feb 22, 2002 | 06:39 AM
EKhatch's Avatar
Default Re: Wider is better!?!?! (itr206)
If a wider tire was a negative adjustment then the newer bikes wouldn't keep coming with wider and wider tires.
Old Feb 22, 2002 | 07:26 AM
im just saying what everyone else has told me . . . the newer bikes got wider tires due to more power being put to the ground
Old Feb 22, 2002 | 07:55 AM
EKhatch's Avatar
So does anyone know the answer to my original question???
I will debate why I think having a wider tire is better if anyone wishes but I really need to find out what rim will fit my F2.
Old Feb 22, 2002 | 07:56 AM
figment's Avatar
New User
http://www.sportbikes.net
go ask in the Honda forum there. Wider is not better IMO for the bike you have.
Old Feb 22, 2002 | 09:51 AM
EKhatch's Avatar
Default Re: Wider is better!?!?! (figment)
Thanks I will check out the link. Why do you say that I wouldn't benafit from a wider rear tire?
Old Feb 22, 2002 | 10:02 AM
figment's Avatar
New User
do you want to run straitline drag races or make good fast turns? If handleing is important, the wider tire will upset the balance of the bike in a turn by adding more rearend lift when on an angle (tire edge). The rest of the bike was not engineered for this.
Old Feb 22, 2002 | 10:27 AM
Luke's Avatar
The answer to the question is...yes/no. If you have an F3 you must be running a 150? If you fit a wider rim you will have two main issues. One the tyre may intefere with the chain, and two could affect the handling. Wider rears are fine but they result in much slower turn in and straightline stability. A better route for ultimate grip would be to mod the forks (change to cartridge style and/or revalve)and rear shock with either a replacement Ohlins etc. or different spring rate to suit your needs.
A CBR F3, does this have the remote shock?? also there was a mod to the rising rate linkage i think plus the shock length was changed as it got worked to hard. Either way there is enough handling to fry anyones brain as the frame design is so right. Upgrade around the bike but dont throw a rim on it and expect transformation, just doesnt happen like that
Old Feb 22, 2002 | 11:03 AM
figment's Avatar
New User
Default Re: Wider is better!?!?! (luke)
My reference to strait lne drag was just being silly. Like slicks on a drag bike
Old Feb 22, 2002 | 10:21 PM
EKhatch's Avatar
Well it is actually an F2 but F2's and F3's all came stock with a 160/60/17 rear. The truth is that I am not a very agressive rider on the street and I will probably be selling the bike soon anyway. I just wanted to fit up a 180 on it so that it would LOOK a little more agressive.
Old Feb 23, 2002 | 05:05 AM
Luke's Avatar
Then it will fit with maybe a mod to the spacers, check chain clearance first!
Old Feb 23, 2002 | 03:55 PM
cbrman's Avatar
f2's and f3's have the same tire size from the dealer, BUT the f3's have a 1/2 inch wider rim. 4.5" vs 5". I should know, I put a set of f3 chrome wheels, f3 plastics and an 98 ss prepped f3 motor into my 94 F2......
The only f2 pieces are the swingarm, and the frame. Anywho.....
If you want to fit a 900rr rim, you need to either make a custom swingarm, or use a 900rr swingarm. I have seen a 900rr swingarm on a f2, but it takes alot of modding the swingarm to work, and looks like *** if not done right.
You can pop an f3 rim into the f2 swingarm, and go a little wider say 170, but 180 is too much for that rim. Also the wider you go on rear tire, the more it affects your handling.
But those fat tires look cool, and make people think you need the extra rubber to keep it down.
Save yourself the hassle, get a 900rr if you want a wider rear tire.
Steven
Old Feb 24, 2002 | 04:32 AM
figment's Avatar
New User
Default Re: Wider is better!?!?! (cbrman)
OT: Hi Mr CBRMAN! I Love those pitbull stands. They're almost too pretty to use though.
Good to see you here.
Old Feb 25, 2002 | 06:26 PM
cbrman's Avatar
Whasap figment. did you see my pic of my cbr or something? YEah the stand has done me very well. Just need to get a front stock stand so I can polish the forks
So did I hear you right in the other posts, you have a xx and a 954rr? Very nice bikes...... Can i ride em?
So you gonna make it over to daytona for bike week????? Are you from sportbikes.net too?
I dont come to the bikes section much but hit the crx/hybrid/performance sections for my car. It's only for rainy days though
Old Feb 25, 2002 | 08:13 PM
BDiddy's Avatar
please see above answers. That would have been mine if i had been paying attention. If it would benifit, then Honda would have done it factory. And why drive a motorcycle straight? NO FUN!!!!
Crazy Ninja
Honda Ruckus and Scooters
Mar 23, 2009 08:10 PM
radarhater
Honda Motorcycles
Jun 8, 2007 09:36 PM
bookzguy
Honda Motorcycles
Oct 13, 2006 03:05 PM
pootsiracer
Honda Motorcycles
15
Mar 14, 2005 02:57 PM
Noahk
Honda Motorcycles
Jul 5, 2004 07:17 AM
