Rear brakes- changing pads
Old Feb 21, 2002 | 06:17 PM
nc-rsx-s's Avatar
New User
Default Rear brakes- changing pads
Anyone here have trouble getting rear calipers back on after changing brake pads? Need help, car on jack stands and track event coming up this weekend...
Driving to VIR tomorrow...
Thanks!
Old Feb 21, 2002 | 06:46 PM
vhd's Avatar
vhd
Default Re: Rear brakes- changing pads (nc-rsx-s)
did you push the caliper piston back in to provide clearance before putting the pads back in? in order to do this, either use a needle nose pliers and turn it clock-wise(using grooves on piston) or use channel locks to grab the piston, be careful not to damage the boot.
Old Feb 21, 2002 | 09:03 PM
nc-rsx-s's Avatar
New User
Default Re: Rear brakes- changing pads (vhd)
Thanks for the reply - I wound up using a hex wrench (lengthwise) that fit into the groove and turning clockwise - worked like a charm.
My problem was not knowing that the pistons need to be turned - was trying to push them in straight. DOH!
Old Feb 22, 2002 | 04:34 AM
therealciviczc's Avatar
Join the club. Only about 90% of the people with rear discs do this the first time. The funny thing is that my neighbor somehow got it to work. I think they pushed so hard that they slowly turned back in. He said it took about 20 min per side
Old Jun 20, 2005 | 01:54 PM
RNPoo7's Avatar
I just changed the front and struggling with the rear. Do you have to take the entire caliper out or can we slide it up or down?
Old Jun 20, 2005 | 02:15 PM
APEX CRX's Avatar
Default Re: Rear brakes- changing pads (RNPoo7)
You can unbolt the caliber from the bracket. 2 bolts and the entire back of the caliper will come off (14mm)
Old Jun 20, 2005 | 03:09 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nc-rsx-s &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the reply - I wound up using a hex wrench (lengthwise) that fit into the groove and turning clockwise - worked like a charm.
My problem was not knowing that the pistons need to be turned - was trying to push them in straight. DOH!</TD></TR></TABLE>
Looks like he got his answer already.
Old Jun 20, 2005 | 04:09 PM
RNPoo7's Avatar
Thanks, I got it.
jadmEM1
Jun 7, 2007 06:05 PM
blulude92
May 15, 2006 01:00 PM
GSR18
Nov 9, 2004 07:58 PM
Beetlejuice
Mar 31, 2004 10:30 AM
Two_K Si
Jan 8, 2004 01:16 PM
