sticky throttle
ok first of all on a 95 prelude where do you jump the ecu to check for codes....
now....just put an aem intake on my prelude and capped that one vacuum hose like the instructions said and now the throttle kind of sticks/surges....when your driving or when you just tap the throttle at idle....also when you are driving the check engine light comes on...please help thanx
CAsey
CAsey
What CEL are you getting? The connector is behind the head unit. It's a blue plug.
And if I remember correctly, you are not supposed to cap any hoses off. They have a little filter that you need to slide over a hose, but not cap a hose off.
the instructions said to cap off that little hose.....it is right above and behind the intake mani and the cap came with the kit.........what do you mean by behind the head unit??....I thought the service point was on the passenger side kinda by the ecu but I could not find it thanx
CAsey
CAsey
Allison Doiron
Feb 20, 2017 05:36 PM
carsaregood
Feb 28, 2002 07:23 PM
