Help 1996 Dx Motor Keeps shutting off while driving
The motor feels weak when trying to go from a dead stop. Today I was driving to the mall the motor just shutdown while I was just rolling in nuetral going about 30mph, I cranked it up and it started back up. While going back home from the mall on the highway going about 110mph on 5th gear the motor shut down again, I put it in nuetral and cranked motor again but will not start, popped it back in 5th gear and popped the clutch to jump start motor but motor will not start, got lucky traffic was way behind and I was in the high speed lane which had no shoulder, so pulled off to the slow lane to the break down lane, cranked the motor but will not start, waited for about 2 or 3 minutes jumped back in car and it started right up. Well let me know if you guys know what the problem could be, thanks.
Ant
Ant
get a new main relay
fuel pump issues probably....
don't be doing 110 either....you have no clue how to control a car at that speed!
def sounds like a prob due to the fuel system might be the fuel pump but could also be a clogged fuel filter try changing ur fuel filter first its the cheapest if thats not the problem check the pump
Yeah I was also thinking it might have something to do with the fuel system but unsure of which part might be the causing the problem, thanks. Anymore info, it will be appreciated, thanks.
Ant
Ant
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ant813 »</TD></TR><TR><TD CLASS="quote">...While going back home from the mall on the highway going about 110mph on 5th gear the motor shut down again,........
Ant</TD></TR></TABLE>
