all motor d15b7 build up
i decided to start a d15b7 all motor build up so far all it has is a neptune and a catback exhaust. im having sum problems finding some 11.5:1 pistons and a good cam what company should i go with or should i put a cam from a nother d series engine in it ?? kinda like puttin ctr internals in a b16 is there a setup i can run like that for d series ive always been a dohc guy but cant afford a b16 now so what can i run in the d15b7
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">don't waste your money!</TD></TR></TABLE>
sorry i'm hating....
You're not!
Read my thread: https://honda-tech.com/zerothread?id=1315461
Building a D-series is honestly the dumbest ******* idea i've ever heard. If you're going to build a motor, start with a better platform. The reason to go D is if you're on a budget (like myself). When you build a motor, you're throwing the budget part out the window.
Stock motor + Cheap Boost = D-series
Built All Motor or Built Boost motor = B or K series
You're not!
im on a budget right now i got a 332 dollar tickett to pay off if im gonna save for a turbo kit i want to go all out with a peak boost or full race but for that money i can just swap in a b16 with ctr internals so im kinda stuck with the d15 right now so i guess im just gonna go with a nitrous kit along with the i h e and the neptune
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotoralldayeveryday »</TD></TR><TR><TD CLASS="quote">im on a budget right now i got a 332 dollar tickett to pay off if im gonna save for a turbo kit i want to go all out with a peak boost or full race but for that money i can just swap in a b16 with ctr internals so im kinda stuck with the d15 right now so i guess im just gonna go with a nitrous kit along with the i h e and the neptune</TD></TR></TABLE>
save your money.....if you are getting tickets with your D series now...just think how many more tickets you will get with that extra 8.9 hp you get from wasting your money on a d series ALMOTA build up....
hahaha....i crack myself up
1st of all...what for? and 2nd, if you want higher compression, use pistons from the d16a6(i think..).
i'm at work right now but when i get home, i'll post a link to a d-series compression calculator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">or parts you can migrate to a b-series.</TD></TR></TABLE>
which would be????? tbody only....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">arent the distributor rotors the same?
exactly my point...
but....
mounts are same
wireharness' to a degree....
slave clutch cylinder....
bolts...
</TD></TR></TABLE>exactly my point...
but....
mounts are same
bolts...
gotta get them staged bolts for that all motor d-series...
at least go dohc zc those are cheap right? boost that, all together ull probley spend like 1500. helpful hint i finally figured out dont get tickets and they wont be a problem when it comes to buy some thing and all u have is enought to pay for somethin dumb
i got my sohc vtec zc for $125
messed up piston but replaced them with some used pistons around the garage and my car runs good. and if i boost it and blow it. wow im out bearly enough money to get 50 gallons of gas
i dono why people seem to think d series motors make no power
a d16 only makes like 30hp less then a b16... WOW.. HOLY **** THATS ALOT... a d16 with a lightened car would beat a stock b16 car...
d series handles turbos great.. boost it **** all motor.... ur d15 is kinda pointless to do anything with though
If you are are building an all motor d15b7 i would for sure do the mini me and with those high compression pistons you sould be in the fourteens easy. If you are in need od a vtec head i do have one for sale with 28k from japan jdm d15b. If you are intrested email me at mgray@woodfins.com or call me at 804-437-3386 and you can have it for $150.00
lessDXHB
Aug 29, 2005 03:02 PM
