Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
OT: changing rear brake pads - trouble getting caliper back on!
Old Feb 21, 2002 | 06:02 PM
nc-rsx-s's Avatar
New User
Default OT: changing rear brake pads - trouble getting caliper back on!
Need help - RSX-Type-S rear brakes (same as Civic I think)
Had a bitch of a time getting the caliper off after removing the retaining screws. Put new pads in, can't get caliper back on...
Tried compressing the piston back in, but it won't budge.
Does it need to be screwed in or something?
Help appreciated!
Old Feb 21, 2002 | 06:21 PM
nc-rsx-s's Avatar
New User
Default Re: OT: changing rear brake pads - trouble getting caliper back on! (nc-rsx-s)
Did a search for this, didn't come up with anything. Schultz telling me to thread the piston back in rather than just pushing it in like the fronts...
Old Feb 21, 2002 | 06:22 PM
Drew M's Avatar
New User
You got it! The piston needs to be turned clockwise and pushed in simultaneously. You need either the proper tool or a pair of needlenose vice grips (other vice grips may work but it will be harder).
r2x's Avatar
r2x
For the Integras, there is a tool to screw the piston back in. Probably a similar thing is needed, but I couldn't say for sure.
Conechaser's Avatar
If it is like Accord/Prelude/Integra you have to screw it in, and it is a BITCH to screw in!
Old Feb 21, 2002 | 06:28 PM
johng's Avatar
Default Re: OT: changing rear brake pads - trouble getting caliper back on! (George Knighton)
If you don't have the tool (like most of us), you can lay a flathead screwdriver down in the + pattern and use it to screw it inwards. It works.
[Modified by johng, 7:28 PM 2/21/2002]
Old Feb 21, 2002 | 06:44 PM
GRM Scott's Avatar
25 Year Member
Default Re: OT: changing rear brake pads - trouble getting caliper back on! (johng)
I have a small crowbar that's pretty wide, fits the into the + pattern nicely and gives lots of torque. On the integra you don't have to push in, just screw it in...pushing will get you knowhere but frustrated, D and I almost knocked his car off jackstands trying to push the sucker in...
Old Feb 21, 2002 | 08:43 PM
nc-rsx-s's Avatar
New User
Default Re: OT: changing rear brake pads - trouble getting caliper back on! (Aleph)
Now I know why I hang out with y'all !!!
Thanks to your advice (and Karl "Rice" Schultz's thru IM), I succeeded in getting those brake pads in... Panther Plus front and rear.
Once you do the first side of the car, the second is a breeze.
I wound up taking my hex key set and found that one of them fit in the groove perfectly. A specialty tool might save a minute or so, but this worked fine!
Just got back from bedding them in - about 10-12 runs of 70mph-20mph until I could smell 'em, then a 15 minute ride home without brakes to cool 'em.
Can't wait to get to the track and have some fun! See y'all there!
Old Feb 21, 2002 | 08:45 PM
Willard's Avatar
Kevin Nealis
Apr 19, 2015 07:53 PM
lowered94accord
Apr 19, 2007 11:46 AM
nubs
Sep 24, 2004 12:45 PM
Two_K Si
Jan 8, 2004 01:16 PM
Cryptopsy
Mar 30, 2003 07:44 AM
