ZC problems
Old Aug 10, 2005 | 03:58 PM
ZCpathatchatch's Avatar
Default ZC problems
I also posted this in the integra section, this should be a good place too.
Ok, I cant get this car started heres whats going on
The motor/car setup
95 civic hatch with 94 Si trans and Integra d16a1 (early ZC) motor.I am using my Civic' ecu and fuel system.
The problem:
I put the motor in and checked timing many times, it has to be correct. I went to start it and it wanted to go but just wouldnt start. Then for some odd reason I decided to pull the cam pos. sensor. The car started, however, it ran like poop. the idle was high and if you hit the throttle, about half way in it would almost stall. you plug the sensor back in and the car wont start again. It has the little cam posistion sensor on the exuast cam kind of like a B 20.
I need help its almost been a week of me trying to get it right, and I am starting to run out of ideas.
thanks,
Nick
Old Aug 10, 2005 | 04:26 PM
Sikocivic's Avatar
Default Re: ZC problems (ZCpathatchatch)
94 tranny will NOT bolt to a D16a1 motor. You better check to see what you have before we can help you.
Old Aug 10, 2005 | 04:41 PM
Default Re: ZC problems (Sikocivic)
when you use a clutch from a d15b7 it will. its the number of splines that is the diffrence using a diffrent clutch/flywheel combination alows it
94gsr_teg
Dec 12, 2007 11:42 AM
h22_crx
Mar 19, 2006 12:18 PM
h22_crx
Mar 9, 2006 07:11 PM
-[sphEre]-
13
Oct 14, 2004 08:08 PM
