what kind of engine do i have?
recently bought a 93 accord ex. i went to get spark plugs and front brake pads at autozone and they want to know if i have nissin calipers or some other brand. that i can find out by simply looking at the calipers, but when i asked for the spark plugs, they had engine choices like F22A1 or F22A6? which one do i have? its a 93 accord ex 5speed. do i have to check with the VIN?
Modified by amir904 at 7:04 AM 8/11/2005
i believe the ex have the f22a6. the dx-lx have the f22a1 dont gert plugs from autozone unless they sell NGK ......ur car takes NGK ZFR5F11...if u can find them at import part store great otherwise get them at dealer..........
as for the brake pads look in the caliper,, name is imprinted there or the back of the old pads assuming they are honda pads and use honda pads as well they dont squeal as much
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealthman80 »</TD></TR><TR><TD CLASS="quote">I put bosche plaitnums in my car is there a problem with usinf these it runs fine. 93 se</TD></TR></TABLE>
get rid of them put NGK plugs
arghhh, which one is it?
http://www.partsamerica.com/Pr...R5F11
http://www.partsamerica.com/Pr...set=A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealthman80 »</TD></TR><TR><TD CLASS="quote">uhh whats the difference? </TD></TR></TABLE>Platinum ones last longer. If you change them yourself maybe not worth the difference. If you pay a mechanic to change your plug, maybe the platinum ones are worth it.
i went with the ZFR6F-11 for the 95 integra and the 93 accord ex, its just a colder plug right? can someone explain to me wat the difference is between a cold and a hot spark plug? in laymans terms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amir904 »</TD></TR><TR><TD CLASS="quote">... can someone explain to me wat the difference is between a cold and a hot spark plug? in laymans terms.</TD></TR></TABLE>
http://www.ngksparkplugs.com/t...ry=US
Halfway down; look for "Why are there different heat ranges?"
If you have a stock engine you don't need ngk plugs unless you're going to fix it up. you might as well go with platinum if you're leaving your engine stock then you dont have to worry about them.
kenandjenn
May 13, 2008 08:04 AM
halfcard
May 13, 2007 09:04 PM
Ideal
Jun 3, 2005 09:21 AM
bswilson
Mar 30, 2004 08:37 PM
