Could you run a B series motor backwards if it was rotated 180 degrees in the bay?
Old Aug 10, 2005 | 02:45 PM
wreckedmyteg's Avatar
Default Could you run a B series motor backwards if it was rotated 180 degrees in the bay?
Stupid question, I know. Let's say for some reason you wanted to put a B series motor in a bay but rotated 180 degrees (like a K series). Could you reverse the plugs and run it clockwise?
What part of the motor is specific to a particular rotation (besides the vanes on the water pump, and the cams)?
Old Aug 10, 2005 | 02:47 PM
mrdeadman's Avatar
They let me pick
Default Re: Could you run a B series motor backwards if it was rotated 180 degrees in the bay? (wreckedmyteg
try it and see.
Thanks, I'll get right on it.
Old Aug 10, 2005 | 03:04 PM
mrdeadman's Avatar
They let me pick
what would the purpose of this be? if you had a point then it wouldn't be so wierd.
Old Aug 10, 2005 | 03:33 PM
old_school_dohcvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">what would the purpose of this be? if you had a point then it wouldn't be so wierd.</TD></TR></TABLE>
i would think so that there is less travel for the intake and exhaust. im not sure, maybe
Old Aug 10, 2005 | 03:36 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
you would need backwards profile crank and cams, some crazy shift linkage, _GAS^ )&%auodgj this makes my head hurt
Old Aug 10, 2005 | 03:45 PM
Racermech's Avatar
Default Re: (^^whatnoobsearchthenGTFO)
LOL this made me laugh after today!!!
Just swap the plugs around, ya go for it, just swap the plugs, but not the wires or there location on the cap...LOL
Old Aug 10, 2005 | 03:54 PM
LostAndFound's Avatar
new motor mounts, and in order to go forward, you would have to be in reverse, correct me if im wrong
that would be pretty cool though, to be able to go 100mph in reverse, just dont turn.
Old Aug 10, 2005 | 03:55 PM
hey maybe in that case. you could move the steering wheel towards the back/tail section of the car, turn the seats around, and have a cheap way to have a rwd integra haha picture that
Old Aug 10, 2005 | 05:55 PM
Default Re: (LostAndFound)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostAndFound &raquo;</TD></TR><TR><TD CLASS="quote">new motor mounts, and in order to go forward, you would have to be in reverse, correct me if im wrong
that would be pretty cool though, to be able to go 100mph in reverse, just dont turn.</TD></TR></TABLE>
If you ran the motor the opposite rotation, you'd go forward, not backwards...
Let's say the purpose was to swap it into a different car (non honda / acura)
So the crank and cams determine rotation? I can see the cams, but how does the crank determine rotation?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">LOL this made me laugh after today!!!
Just swap the plugs around, ya go for it, just swap the plugs, but not the wires or there location on the cap...LOL</TD></TR></TABLE>
I was referring to the plug wires.
Old Aug 10, 2005 | 06:00 PM
weak_tec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostAndFound &raquo;</TD></TR><TR><TD CLASS="quote">and in order to go forward, you would have to be in reverse
does taht mean ur odometer goes backwards
Old Aug 10, 2005 | 06:05 PM
Naruto's Avatar
Default Re: (wreckedmyteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wreckedmyteg &raquo;</TD></TR><TR><TD CLASS="quote">If you ran the motor the opposite rotation, you'd go forward, not backwards...
but with the way the transmission turns in the B series motor, if you were to face it backwards I believe Lost and Found would be correct. However, if someone knows of a way to correct that then I guess it would be possible. Why not just get a K-series to alleviate that?
Old Aug 10, 2005 | 06:27 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: (psychoticmindset)
I used to run with a backwards B18c way back in 91'. We did it because Kriss Kross wore their clothes backwards, so we thought "hey! Why not put our motors backwards too?" And so we did.
"Because inside out, is wickity, wickity, wickity, wickity, wack!"
Old Aug 11, 2005 | 07:21 PM
98acura's Avatar
Another problem with spinning the motor wrong, timing belt. its designed to spin one way, spin it the other and youll likely loose tension on it.
Old Aug 14, 2005 | 06:01 PM
weak_tec's Avatar
Default Re: (98acura)
i like taht avatar....what does it say??? always wanted to see if it goes beyond 100mph, im goin to do it one day
Old Aug 14, 2005 | 06:07 PM
Slammed89s10's Avatar
seems like more work then its worth unless youve got too much time on your hands to try it.
Slowp0ke
Dec 1, 2010 12:06 PM
kenny7231
Jan 9, 2008 08:23 PM
perseverance
Sep 20, 2006 05:21 AM
rice is nice
13
Jan 3, 2006 07:55 AM
Slo Honda Driver
Aug 16, 2005 01:59 PM
