Good shops in dfw area? get work done with out getting ripped off!
Old Aug 10, 2005 | 01:50 PM
decent's Avatar
Default Good shops in dfw area? get work done with out getting ripped off!
Prefer Lewsiville area if possible.
Old Aug 10, 2005 | 02:21 PM
eightyHD's Avatar
Default Re: Good shops in dfw area? get work done with out getting ripped off! (decent)
why do you need to go to a shop???
Try to post here and get some ideas first before you go to the shop.
What i do is go to the shop in my dirty *** coveralls, and get some grease on my hands, and take it to the shop and tell them you already tried to fix "the Problem" and the ****** thing isnt workin, whats the cost for the labor?
Usually they'll be straight up with you.
I changed out the clutch w/my roommate, and it was sunday night when my car didnt go into gear or wouldnt even start at all.
$300 bucks for new starter and to put the ****** clutch in the right direction and tighten the 4 bolts that were about as loose as my roommates brains....
Old Aug 10, 2005 | 02:41 PM
decent's Avatar
put a new engine harness on car (all obd 1) and the car starts than immeditly shuts off i checked all the connections and i think im just missing something but its really pissing me off...
car ran before i changed the harness.....
Old Aug 10, 2005 | 02:45 PM
eightyHD's Avatar
Default Re: (decent)
Specify
Your car:
The New Harness Yr/mk/Mdl:
What was wrong with old Harness:
Old Aug 10, 2005 | 03:07 PM
decent's Avatar
97 integra gsr
with ls/vtec b16 head
had obd1 ls engine harness no vtec( did not want to run wires) bought a obd1 gsr harness that had more wrong with it than i was told had to end up splicing a lot of wiring and trying to make it work and it gave me the idea it was just a p.o.s harness i bought another one from a forum member and it lookes like its in great shape compared to the old one and i wired it up and same damn problem the car starts then immediately dies.
decent's Avatar
sorry about the grammer!
Old Aug 10, 2005 | 03:41 PM
B20TDC2's Avatar
check and make sure all of your connections are correct i remember with my last build. i got the thing together no start . it turned out to be that i had mixed up 2 connectors took it to a friends shop 1 min after i got it off the trailer it was running
Old Aug 10, 2005 | 04:49 PM
decent's Avatar
thanks bro ill go double check..........thats what i keep thinking......i just mixed up a connection its like racking myself over and over again
Old Aug 10, 2005 | 05:33 PM
decent's Avatar
FUKIN A got it running...... thanks eightyHD and b20tdc2 I had a mixed up 2 connectors!LMAO
truckmonth
Nov 17, 2010 09:02 AM
gobblebox59
Apr 21, 2005 08:23 AM
inspyral
Feb 5, 2003 02:27 PM
