mix match D series parts Q's
Old Aug 10, 2005 | 01:32 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default mix match D series parts Q's
i got sevral questions about vairous Dseries parts for my MPFI swap.
1. will a D16A1 TB (intake code PG7)fit / work on a SI IM (code PM6)?
2. i can put obd1 injectors in a SI IM with SI rail. the only diffrance is the wiring right?
3. the exsisting yel/blk wire going to the 2 injectors; i can use eather one and cut off the other one to hook up the MPFI setup. is this correct?
4. my car is a CA emmisions and my DPFI has a EGR on it but the MPFI dossent. will i get in trouble when i go smog it? or will they not give it a second look?
Old Aug 10, 2005 | 01:55 PM
ham's Avatar
ham
Default Re: mix match D series parts Q's (DieMaster)
1. will a D16A1 TB (intake code PG7)fit / work on a SI IM (code PM6)? At first I thought it said d16a1 IM on an Si, thats a no. As far as the TB, im not 100% sure but I believe that's a no.
2. i can put obd1 injectors in a SI IM with SI rail. the only diffrance is the wiring right? The only difference is they are high impedence (no resistors)
3. the exsisting yel/blk wire going to the 2 injectors; i can use eather one and cut off the other one to hook up the MPFI setup. is this correct? The yel/blk wires are voltage to the injectors, the signal is the ground. Use one or both to branch to all injectors for power. Remember, the injector is just a solenoid.
4. my car is a CA emmisions and my DPFI has a EGR on it but the MPFI dossent. will i get in trouble when i go smog it? or will they not give it a second look? I think you will get hassled but they might let you slide if your exhaust is clean.[/QUOTE]
Old Aug 10, 2005 | 03:39 PM
DieMaster's Avatar
bump
i need a defanint yes or no.
i think the TB is too big but i need asners from pepole that have done it.
Old Aug 10, 2005 | 04:31 PM
Sikocivic's Avatar
#1. Yes it will fit
#2. Yes you can
#3. I don't know
#4. CA smog testing SUCKS. Move to a different state.
hypeonline
Sep 6, 2013 10:49 AM
turbohatchBnuts
May 12, 2011 06:14 PM
Htounndea
Feb 24, 2010 11:28 AM
Mr_Moos
Jan 20, 2006 11:57 PM
TEAM HATCH-N-IT 90
Jan 27, 2005 06:07 PM
