93 civic auto trans to manual swap
Old Aug 10, 2005 | 12:15 PM
BenzTek134's Avatar
Default 93 civic auto trans to manual swap
has anyone done this swap how difficult is it? what parts are all involved/needed?
any help will be greatly appreciated.
Old Aug 10, 2005 | 12:20 PM
BenzTek134's Avatar
Default Re: 93 civic auto trans to manual swap (BenzTek134)
anyone out there done this swap or can direct me down the right path of someone that has??
Old Aug 11, 2005 | 10:02 AM
doublejz's Avatar
its very easy, i did a 93 ex auto to man 3 years ago. just get a tranny, linkage, hydro lines, pedal assembly, auto to man HCP mount from jdmshit.com. you'll have to splice a couple wires together like the interlock control think so if wont check to see if your in park or neutral which it wont be b/c the auto shifter will be gone so you wont be able to start :-P also have to wire up reverse lights manually from the tranny to the harness in the car where the auto shifter was pulled from. you'll have to either weld, bolt or do something to cover the huge hole from the auto shifter then drill a hole where the man shifter/linkage lines up in the piece you just put in.
it cost me $90 for junkyard parts and got the tranny with my swap, $300 for a clutch kit.
Joey_bornander
Honda Civic (2006 - 2015)
Sep 12, 2016 10:09 PM
JDM-ish
Mar 15, 2010 06:02 PM
srt4pilot
May 28, 2009 03:02 AM
boosted97civic
Jan 10, 2007 09:40 AM
CTRwannaB
Sep 9, 2006 11:08 AM
