b16 stock compression w/ junIII's??
Old Aug 10, 2005 | 10:54 AM
punx04's Avatar
Default b16 stock compression w/ junIII's??
http://www.g-speed.com/eg2/mods.shtml <--- the mods
https://honda-tech.com/zerothread?id=1259496 <--the dyno(half way down page)
could i run jun III's on a almost stock compression. maybe flat valves and mugen h/g and have it run fine? or should i stick with sk2s1's?
Old Aug 10, 2005 | 01:02 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: b16 stock compression w/ junIII's?? (punx04)
On stock compression you only going to see gains in the upper rpm range, Why are you using ZFR7F-11, thats a colder plug for an ls motor, with your compression id stick to a bkr6en11 or a bkr7e11, I would throw in a set of ctr's with new rings, or a set of p30's and shave the head .030. Those cams work alot better with higher compression.
Old Aug 11, 2005 | 12:58 AM
punx04's Avatar
quick note...that isn't my car. i was just interested in the setup soo...yah but the cams seemed to pull decent #'s
3easy21
Apr 2, 2013 12:25 PM
djangel1343
Nov 14, 2007 12:30 PM
nokturnal_munkeeboy
Jul 23, 2006 08:50 PM
Dan GSR
Aug 27, 2004 07:15 PM
blufke
11
Dec 30, 2003 09:07 AM
