HELPP!!! ACCORD MISFIRE CYLINDER 2?????
Old Aug 10, 2005 | 08:21 AM
Metzler's Avatar
Default HELPP!!! ACCORD MISFIRE CYLINDER 2?????
i have a 93 accord and it is missfiring on cylinder 2, after replacing plugs and wires it still continues to do this
Old Aug 10, 2005 | 08:48 AM
tyro's Avatar
Default Re: HELPP!!! ACCORD MISFIRE CYLINDER 2????? (Metzler)
Cap and rotor too?
Old Aug 10, 2005 | 12:35 PM
deserthonda's Avatar
do a compression test ............. if all even you could have a bad injector, did old plugs look clean or contamineted ,,,,
Old Aug 10, 2005 | 05:09 PM
P_Adams's Avatar
I feel like part of a tag team.....
Anyway, After <U>checking the Cap and Rotor </U>(Buck Turgidson) and after <U>performing a Compression test </U>(deserthonda), chk the vacume hoses in the vicinity of the Intake Manifold / Throttlebody. Vacume leaks can cause individual cylinders to misfire if they're located close to the effected cylinders' intake runner.
It will probably be something else, but it's still something to be checked
P
Old Aug 10, 2005 | 05:22 PM
hondaracin24's Avatar
Default Re: HELPP!!! ACCORD MISFIRE CYLINDER 2????? (P_Adams)
Definatly do a compression check. I had the same problem with mine with a missfire on cylinder 1 and about a month later my engine went kaput.....
Jyankel
Oct 23, 2016 05:27 PM
BillLen
Jun 22, 2016 10:54 AM
turboD_EG
Apr 17, 2009 07:19 AM
LSVTEC 91 Civic
25
Jul 12, 2004 01:49 AM
Qwikrex
Apr 11, 2003 09:08 PM
