itb's + iac + brake mc + map sensor + vacuum can..... how did you route yours?
I've got the itb's pulling vacuum from the 4 runners and going to the vacuum can.
map sensor is mounted at one end of the can. At the other end of the can, there's a vacuum line going to the fpr. There's one additional port going to the brake master cylinder.
I'm getting mid 300 mm/hg to mid 400mm/hg at idle.....
Now, I was considering running the brake master cylinder vacuum to a port on the itb runner #1 instead.
Then I could use that extra port on the vacuum can for the IAC (currently not connected to any vacuum source).
How have you connected your vacuum can, and why?
how do u setup the iac??? do u know... im having trouble figuring that out... as well...im gettin my twms ready to put on... any input would help... i got the golden eagle vaccum log..how should i setup the iac.
no need for the IAC....just leave it pluged in and strap it some where...
you just need a vacuum can/log for the map and brake master cylender.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">
where did you get that?
</TD></TR></TABLE>where did you get that?
I made my own vacuum manifold. I tapped some NPT holes in it for hose barb connectors for everything, and my AEM MAP sensor screwed right into a NPT hole. I just use a small valve with a fuel filter on it as a manual IACV, I set it so it idles correctly when warm, and it idles a bit low when warming up, but I goose it a few times and it's fine. Here's a pic:
im pulling 440mm staright off the itbs to the map sensor. but now that i have conected my can im onl y pulling 260. I am going to start investigating posibble vac leaks.
i have all runners connected to the can. then brake booster, catch can, map, egr/fpr get their own nipples out. I dont run a iacv because im obd0 and it was easy to eliminate it. I just got it running and with a little work to the map im at 13.5:1ish a/f at idle. but i do have to source where the vac is leaving at still.
heres how i tapped for the lines.
m.
m.
Now, I was considering running the brake master cylinder vacuum to a port on the itb runner #1 instead. </TD></TR></TABLE>
Don't. The individual pulses will suck. Hook up a vacuum gauge to a single runner and you will see what I am talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">Don't. The individual pulses will suck. Hook up a vacuum gauge to a single runner and you will see what I am talking about. </TD></TR></TABLE>
I thin I'm going to try it out and see how it feels...
The toda itb's are actually made for lhd or rhd cars and have ports on runners #1 and #4 for the brake booster vacuum...
Didn't Len and Greg Samaroo run off of them this way.....?
Let me see if I can dig up some pics. It'll be really easy to test out and see how it feels.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4ornia »</TD></TR><TR><TD CLASS="quote">HEY I PMD U DID U GET IT?</TD></TR></TABLE>
Bumping an almost 2 year old thread with all caps about PM'ing someone
If you PM'ed him like you posted in here, its no wonder you havent gotten a response.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption »</TD></TR><TR><TD CLASS="quote">
If you PM'ed him like you posted in here, its no wonder you havent gotten a response.</TD></TR></TABLE>
WHO GIVES A *** does all caps bother you that much? go cry about it take you r internet eddicate and shove it up your ***
turbotime
Oct 6, 2005 11:30 AM
