Washer Reservoir do you still have it with your turbo?
hello everybody.
i was wondering how many of you still have the Washer Reservoir with your turbo?
im haveing a hard time routing my chargepipes with the Reservoir do you guys have any suggestions besides removeing it?
I removed mine but I've seen people that got smaller ones, and others fit the pipe around it somehow. I really hate having a dirty winshield but I can live without the washer fluid, you'd get used to it too...
I routed my charge pipe under the stock reservoir because I didn't want to get rid of it.
There was just enough space for my 2.5" charge pipe to fit under the reservoir without sticking out below my bumper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">I routed my charge pipe under the stock reservoir because I didn't want to get rid of it.
There was just enough space for my 2.5" charge pipe to fit under the reservoir without sticking out below my bumper. </TD></TR></TABLE>
same here
same here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVtec-T »</TD></TR><TR><TD CLASS="quote">
same here</TD></TR></TABLE>
Same here too.
Same here too.
I went to honda and bought a brand new coolant over flow tank. Drilled a hole in the top the size of the washer pump, and stuck it right where the charcoal cansister goes in the EF chassis. Moved the wires over and your set. Doesnt last as long as the other one, but filling it up isnt hard.
I'm just finishing mine up today, and I was able to keep the stock washer reservoir. I cut through the fram near the reservoir and was able to fit the 2.5" pipe through there without hitting the reservoir.
Why dont u just stick it in the fenderwell area? I mean you dont really have to fill it up that often do you? And removing the bumper isnt that hard either.
For me, honestly, I hardly ever use it. When I go and pump my gas I just use the little brush they provide and clean my windows with that
