Stock counterparts for Hasport mounts?
Old Aug 9, 2005 | 06:45 PM
Stoich's Avatar
Default Stock counterparts for Hasport mounts?
My hasport mounts are too hard for my tastes
Are there any stock mounts i can use for a B series in an Ef chassis?
Old Aug 9, 2005 | 07:32 PM
Crx Jimmy's Avatar
Default Re: Stock counterparts for Hasport mounts? (Stoich)
pull the urethane out of the mounts and measure it and call energy suspension and see if they have something softer and close in size
Old Aug 9, 2005 | 07:42 PM
Slowass4dr's Avatar
not that am saying this will work for sure but my cusin took the mounts out and made holes with a drill and it seemed to vibrate way less, but again not sure
Old Aug 9, 2005 | 07:58 PM
DohcVtecCrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stoich &raquo;</TD></TR><TR><TD CLASS="quote">My hasport mounts are too hard for my tastes
Are there any stock mounts i can use for a B series in an Ef chassis?</TD></TR></TABLE>
Nope just use the stiff ones
Old Aug 10, 2005 | 04:53 AM
Stoich's Avatar
Default Re: Stock counterparts for Hasport mounts? (DohcVtecCrx)
What did people do before hasport made mounts?
I cant keep these they are soooo hard
Old Aug 10, 2005 | 07:12 AM
EP3_05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stoich &raquo;</TD></TR><TR><TD CLASS="quote">What did people do before hasport made mounts?
I cant keep these they are soooo hard </TD></TR></TABLE>
People would cut off the mount brackets on the chassis and reweld them so that they could use integra mounts. This is a totally custom process and if done a lot of effort should be taken to assure proper axle alignment and ground/hood clearance.
Old Aug 10, 2005 | 10:20 AM
Bett than solid metal mounts like alot of the Domestic guys use. It really isn't that bad so don't be a *****.
Old Aug 10, 2005 | 10:32 AM
BiG Chris's Avatar
my friend got some ebay mounts from ny and they have a choice of the insert for the mounts i dont know the name but if you cant find them ill ask him ohh and they are a cast mount not billet
Old Aug 13, 2005 | 03:03 PM
Stoich's Avatar
Default Re: (BiG Chris)
Where there no Jdm or euro Efs with Bseries stock? would those mounts work?
Old Aug 13, 2005 | 03:08 PM
Default Re: (Stoich)
yeah they sure will...in a DA
Old Aug 13, 2005 | 03:10 PM
Kryogen's Avatar
yeah, Stock JDM EF mounts will work from a siR. but finding them could prove to be a problem....unless you worked at Honda, and had the OEM part #'s and could order some new ones....
That could prove to be a pain.
Maybe Ebay UK? oneday maybe some mounts would come up for sale...
Old Aug 13, 2005 | 03:12 PM
Kryogen's Avatar
Default Re: (DohcVtecCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcVtecCrx &raquo;</TD></TR><TR><TD CLASS="quote">yeah they sure will...in a DA</TD></TR></TABLE>
Why do people post and TRY not to add anything helpful, people like that are what make this site WEAK.
people come here for help, and guys become smartasses and do not even post anything relevant or post useless info to the post...
Old Aug 13, 2005 | 04:34 PM
Default Re: (Kryogen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kryogen &raquo;</TD></TR><TR><TD CLASS="quote">yeah, Stock JDM EF mounts will work from a siR. but finding them could prove to be a problem....unless you worked at Honda, and had the OEM part #'s and could order some new ones....
Maybe Ebay UK? oneday maybe some mounts would come up for sale...</TD></TR></TABLE>
Nope they will not work, posting misinformation is worse than less than helpful information. You ever see full sir front clips? They use the same mount points as the DA, and the front end is longer. A jdm sir1 comes with the stock mounts on it, they are the same as the DA (90-93 teg here in the us = DA) THEY WILL NOT WORK IN A USDM CAR!!!!!!!!!
The problem is he wants the power of a b16a, with stock feel with stock motor points. Given that info he can cut his mount points and line them up to the sir/DA oem mounts or he can have a stiff mount with an aftermarket mounting kit. Those are your choices. 99.9% of people here have stiff mounts. I love it that way, some like it some do not. But ask yourself how many people want or have inserts or equivilent to stiffen up their stock oem mounts cause you loose power to the wheels and break **** without them.
Old Aug 13, 2005 | 04:36 PM
people come here for help, and guys become smartasses and do not even post anything relevant or post useless info to the post...</TD></TR></TABLE>
People posting BULLSHIT info brings down the site and it's members, not to mention the guy is prolly looking all over for some mounts he would get on his swap, that will NOT work in his car, from info he got from your dumbass post.
Old Aug 13, 2005 | 04:42 PM
Boosted Rex's Avatar
so in other words there are no stock counter parts for the hasports or everyone would use them....just use the hasports you'll be thankful in the long run
Old Aug 13, 2005 | 05:22 PM
Stoich's Avatar
Default Re: (Boosted Rex)
Well i guess ill have to suck it up and stick with these rocks.
BTW don't flame him cause he is right in any given post there will be 5 smartass/******* comments and maybe MAYBE one relevant or helpful post
Old Aug 14, 2005 | 07:56 AM
Wes V's Avatar
You could build your own mounts and use rubber bushings. You will need all four mounts to do it correctly.
Keep in mind that this isn't easy or "cost effective" in most cases.
Here is a link to what I did; (I'm one of the 0.1% that don't just buy a set of mounts, and live with the vibration)
http://www.performanceforum.co....html
Wes
miked123
Sep 10, 2013 04:08 PM
tonylovesjdmEF9
Sep 30, 2011 03:36 AM
russianswty
21
Oct 16, 2006 05:48 AM
racingant
10
Mar 13, 2004 07:17 PM
