ls crank+gsr block= oil squirt problem
okay guys i threw in a ls crank into gsr block and i have major oil squirt problem. So i decided to get the golden eagle plugs to plug it up. But i encounter a problem, one of the hole that the GE plug plugs into, i stripped the thread. Now only 3 cylinders are plugged and the 4th is left open. Will this affect the oil pressure or anything? I mean its just a hole where oil goings into and comes out of. Can i run it like this and will it matter, or does anyone have a way to fix this? I would take it info for it to get it retap but i dont know a shop in town. Also won't that make the hole bigger so that means the plug wont fit anymore? HELP need this in by 2 week i have school and no car!
HELP
HELP
call a machine shop, you need to have it tapped and over sized, helicoiled, or welded shut. It will effect oil pressure. Search around, someone near you will be up to the task.
That main oil galley that those squirters go into can be accessed by taking out the two large plugs using a 14mm allen. That size bolt, 6mm by .75mm pitch is hard to come by. I'd suggest drilling it out and tapping it to 1/8 NPT and plugging it like that. Make sure you clean the block very well afterwards.
well i tried to bend them and it does not work. I've heard people say bend them left right, up, down and it doesnt work for me. The bigger side of the counterweight on the 2nd and 4th cylinder are bigger then the 1st and 3rd cylinder. Which causes it to hit the oil squirters. That is why i decided to go with the GE plug but evidently it stripped on me on the way down. SUCKS ***!!!
Thanks guys for the input. Anyone with anymore suggestions please do so too.
THANKS
THANKS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blu3g »</TD></TR><TR><TD CLASS="quote">well i tried to bend them and it does not work. I've heard people say bend them left right, up, down and it doesnt work for me. The bigger side of the counterweight on the 2nd and 4th cylinder are bigger then the 1st and 3rd cylinder. Which causes it to hit the oil squirters. That is why i decided to go with the GE plug but evidently it stripped on me on the way down. SUCKS ***!!!
THANKS</TD></TR></TABLE>
WOW...sorry to hear...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">Tap the hole with an 1/8 pipe tap, as has been suggested, and put in a 1/8 pipe plug. Clean the main oil galley after.</TD></TR></TABLE>Just like he says. You do NOT need to drill the hole that is there. It is the perfect size for the 1/8" pipe tap. Clean the main oil galley afterwords.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blu3g »</TD></TR><TR><TD CLASS="quote">Well if i do decide to retap the hole and plug it up with a bigger 1/8, would any bolt be fine or would i have to get a special high temp bolt for it?</TD></TR></TABLE>
any bolt the right size will work, your not putting it in the oven LOL
blu3g
26
Aug 2, 2005 09:22 PM
