Will a b18c1 wiring harness work with a b16a2 motor
Old Aug 9, 2005 | 05:38 PM
redimport95's Avatar
Default Will a b18c1 wiring harness work with a b16a2 motor
Please help.. I just recently bought a b16a2 (everything needed for swap except wiring harness) motor and i have a b18c1 94 integra wiring harness will it work?
Old Aug 9, 2005 | 05:57 PM
SirRevvs's Avatar
Default Re: Will a b18c1 wiring harness work with a b16a2 motor (redimport95)
Yes
Old Aug 9, 2005 | 06:01 PM
eg crunkmonster's Avatar
what car will it be going into? If it is a 92-95 civic or 94-01 integra than yes. You will just have an extra plug for the secondary's. Also, if you have the obdII (off the b16a2) distributor and alternator than you will have to repin the distributor plugs to OBDII along witht he alternator (I never did the alternator so I think you might have to cut and paste the wires) Also, the injector harnesses are different. Just swap them for ODBII clips and solder and heat srink them
4gencivicef9
Jul 27, 2006 05:37 PM
redimport95
Aug 10, 2005 07:35 PM
Radyjr
Feb 19, 2005 11:08 PM
GummyBeng
Feb 3, 2003 06:18 PM
