<~~~STRAIGHT PIPE QUESTION~~~>
Old Aug 9, 2005 | 05:21 PM
redlinez_r_us's Avatar
Default <~~~STRAIGHT PIPE QUESTION~~~>
does any one know what happens to the ECU if you put a striaght pipe on a Honda Civic 00 EX with OBD2 ECU? what kind of ERROR CODES will it give? will it damage the Speed/Odometer dial? thank you every one for your help.
Old Aug 9, 2005 | 05:23 PM
kaoss_11's Avatar
B A N N E D
you will get a raspy sound.
Old Aug 9, 2005 | 05:25 PM
AutoXer's Avatar
Default Re: <~~~STRAIGHT PIPE QUESTION~~~> (redlinez_r_us)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinez_r_us &raquo;</TD></TR><TR><TD CLASS="quote">what kind of ERROR CODES will it give? </TD></TR></TABLE>
You will get 02 error codes. It will probably throw the car into limp mode, and will decrease your performance. Also, you will never pass emissions with a straight pipe, and it's a federal crime to remove emissions equipment. You'll only gain 1 or 2hp (if you do a bung or 02 simulator); it's just not worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinez_r_us &raquo;</TD></TR><TR><TD CLASS="quote">will it damage the Speed/Odometer dial? </TD></TR></TABLE>
I'm not even sure what you mean by this... but no, your speedometer is run by the VSS on the transmission.
Old Aug 9, 2005 | 05:30 PM
Default Re: <~~~STRAIGHT PIPE QUESTION~~~> (AutoXer)
this are the ERROR CODES that i got when i did the straight pipe...
P0135
P0141
P0500
P1298
how to fix this ERROR?
I just got a new Cat for my Car...
have not tried to put it on though because im still concern about the ERRORS...
Old Aug 9, 2005 | 05:32 PM
Gunmetal_B20_Hatch's Avatar
Yes, if you install a test pipe (straight thru cat) you will get louder and more of a raspy growl to your exhaust. I like the way mine sounds.. Skunk2 MP cat-back & Invidia TP. I love it. of course mine is on a 92 DX (OBD1). I didnt get any error codes. You may want to disconnect your batt cables to reset the ECU feul map, tho.
Old Aug 9, 2005 | 06:20 PM
AutoXer's Avatar
Default Re: <~~~STRAIGHT PIPE QUESTION~~~> (Gunmetal_B20_Hatch)
https://honda-tech.com/zerothread?id=1171263
P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfunction
P0141 Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater Circuit Malfunction
P0500 Vehicle Speed Sensor (VSS) Circuit Malfunction
P1298 Electric Load Detector (ELD) Circuit High Voltage
In the future, you might get better responses if you post the problem, and what the codes are. From the looks of it, I'd check some fuses. I don't know what circuit the VSS and 02 heaters are on, but they could be on the same one, and with the high voltage detected, it could be related.
I'd put the new cat on, hook up your secondary 02 sensor, and reset the ECU (pull both the neg and pos leads from the battery, and touch them together - make absolutely sure you don't do this while they are connected to the battery). Then see what codes you get.
If you're still getting the third code, you'll need to look into your VSS, which is why I'm guessing you asked about the speedo. If your VSS isn't working, your speedo won't work either.
I'm not sure about the 4th code, I haven't seen that one before on any car I've worked on, but I'd start with the cat, then the VSS and go from there.
Old Aug 9, 2005 | 06:22 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote"> It will probably throw the car into limp mode, and will decrease your performance.</TD></TR></TABLE>
I doubt that the secondary O2 sensor reading a cat not functioning properly will put a car into limp mode.
As a matter of fact, I'm almost positive it wont.
Old Aug 9, 2005 | 06:55 PM
AutoXer's Avatar
Default Re: <~~~STRAIGHT PIPE QUESTION~~~> (JDM-97CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">
As a matter of fact, I'm almost positive it wont.</TD></TR></TABLE>
Yes, you're right, if it was reading the cat not functioning properly, it wouldn't throw the car into limp mode. Not having a secondary 02 hooked up at all with a straight pipe could, since the ECU would not be getting any reading at all.
Old Aug 9, 2005 | 07:37 PM
so you mean to tell me that the ERROR that my car has, has a lot to do with the 02 #1 and 02 #2? or its because of the car having a straight pipe?
renton
Honda Civic (2006 - 2015)
10
May 30, 2007 03:51 PM
bertyman
38
Sep 25, 2005 11:46 AM
SupaFly_Honda
Honda Motorcycles
17
Feb 20, 2005 01:18 AM
infamousALLMTR
Oct 24, 2003 04:18 PM
yellowbuffalo
May 26, 2003 12:38 PM
