valve cover bolt stripped
Old Aug 9, 2005 | 05:13 PM
happy_guy's Avatar
Default valve cover bolt stripped
one of the 4(or 5?) bolts that hold on my valve cover is stripped. it turns in both directions but wont tighten or loosen. its the lower left one. whats it called?(so i can get a replacement from honda) also whats the stuf that it goes onto called?. and, how do i take it out.?
Old Aug 9, 2005 | 06:09 PM
Liquid Ice NF's Avatar
Default Re: valve cover bolt stripped (happy_guy)
**** dude.. u sure its the bolt and not the valve cover? if its just the bolt, i'm sure you can order one from honda.. or even autozone or something.
Old Aug 9, 2005 | 06:36 PM
97Alex's Avatar
Situation A:::
You stripped the threads and need to re-tap them.
Situation B::
It's called a valve cover bolt, just tell the honda parts counter person u need that.
Best way to remove it would probably be to just remove the valve cover and go from there. If the bolt is stickin out from the head then go ahead and just get some pliers to back the bolt out. If the bolt was broken flush with the head, meaning threads of the bolt is not sticking out, then you need to to either
A- Drill it out, re-tap the threads
B- Drill small hole into the bolt itself and use an extractor (from homedepot or similar place) to take it out.
Its easy job really..
And no, as liquid ice mentioned it cannot be the valve cover. If the bolt head is spinning
SlowB16si
Jan 28, 2006 02:13 PM
renzema
Aug 29, 2005 09:42 AM
jdmsijdm
May 11, 2004 07:31 AM
freeeked
Aug 16, 2003 04:19 PM
LoudAccord
Jan 9, 2003 10:43 AM
