jdm gsr in civic running too rich....vafc or hondata
ive got a stock jdm gsr in a 97 civic coupe. its running way to rich with the p2t ecu....im sure its been covered before, which way would be better to tune with, a vafc or hondata?...........thanks
Maybe you should use the correct obd 2 p72 gsr ecu to match your motor and wire in the secondaries. Im sorry but using a vafc as a bandaid for the wrong ecu is a waste.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR »</TD></TR><TR><TD CLASS="quote">Maybe you should use the correct obd 2 p72 gsr ecu to match your motor and wire in the secondaries. Im sorry but using a vafc as a bandaid for the wrong ecu is a waste.</TD></TR></TABLE>
its got a skunk2 manifold on it, so if i had the stock one, id go that route. but, thats the way i bought it. sorry, i shouldve put that in the first post....i was told the ecu is a jdm one which i think that it is b/c the motor doesnt have a knock sensor, 2nd O2 etc...etc....and ive got no cel's, just running way to rich.
Speed Infliction
Jun 9, 2006 09:26 AM
Tex Blackwell
Jul 14, 2004 05:25 PM
