which valve springs?
Old Aug 9, 2005 | 01:42 PM
lopaka07's Avatar
Default which valve springs?
Just picked up a set of ctr cams and it came with crower valve springs (NOT the hi-pressure ones). All are brand new... cams and valve springs. But I'm wondering if the valve springs may be too stiff for the cams and wear them out. I don't understand the specs of the valve springs on the http://www.crower.com website... can somebody help out? I know the seat pressure of the type r's are 50 lbs and open pressure is 150 lbs @ 11.5mm
Here's the link: http://www.crower.com/cat/impo...shtml
It's the 68185-16 part number. I would prefer using the itr valvetrain but I already have these valve springs just sitting here.... Thanks for any help
Old Aug 9, 2005 | 03:45 PM
Big Phat R's Avatar
Default Re: which valve springs? (lopaka07)
why don't you just use ITR springs
Old Aug 9, 2005 | 06:39 PM
TheOne's Avatar
TODA valve springs. 10k rpm red line-all day!
Old Aug 9, 2005 | 10:10 PM
vtecvoodoo's Avatar
Future Texas Boy
Eibach
Realtime Racing just uses our off the shelf spring for ALL of their motors
Old Aug 9, 2005 | 10:16 PM
RagingAngel's Avatar
Default Re: which valve springs? (vtecvoodoo)
HAhaha....
Unless you've seriously overrev'd your motor in the past.... I'd just drop the cams in and call it good
If you are lookin for a replacement, OEM ITR is just perfect....
Old Aug 9, 2005 | 11:40 PM
PURPLETERROR aka BIGMATT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">Eibach
Realtime Racing just uses our off the shelf spring for ALL of their motors </TD></TR></TABLE>
What kind of lift can your springs handle? and do you offer retainers also? bseries
Old Aug 10, 2005 | 09:44 AM
lopaka07's Avatar
Thanks for the info guys. But like I said, the only reason I'm considering the crower springs is because they are sitting here in my garage.
Old Aug 10, 2005 | 03:09 PM
daddy ITR's Avatar
Default Re: which valve springs? (RagingAngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
I replaced my OEM ITR springs with Skunk 2 ........ the OEM start to fatique at 8500 rpm
Old Aug 10, 2005 | 03:41 PM
MattD@Stoptech's Avatar
Default Re: which valve springs? (daddy ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daddy ITR &raquo;</TD></TR><TR><TD CLASS="quote">
the OEM start to fatique at 8500 rpm </TD></TR></TABLE>
what?
Old Aug 10, 2005 | 03:50 PM
nholmes's Avatar
Default Re: (TheOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheOne &raquo;</TD></TR><TR><TD CLASS="quote">TODA valve springs. 10k rpm red line-all day!</TD></TR></TABLE>
I know TODA is good, but 10k? I call shenanigans!
Old Aug 10, 2005 | 03:51 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: (nholmes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nholmes &raquo;</TD></TR><TR><TD CLASS="quote">
I know TODA is good, but 10k? I call shenanigans!</TD></TR></TABLE>
Why? Their larger cams still make power that high, why not build springs that can handle it?
Old Aug 10, 2005 | 03:55 PM
Misfit's Avatar
I vote that if you don't know what you are talking about, you don't post.
Old Aug 10, 2005 | 05:12 PM
BlueR's Avatar
Default Re: (Misfit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Misfit &raquo;</TD></TR><TR><TD CLASS="quote">I vote that if you don't know what you are talking about, you don't post.</TD></TR></TABLE>
then we would have less than 10 people posting all day
Old Aug 10, 2005 | 05:29 PM
chad's Avatar
Moderator
well you are WRONG!!!!!!!
took my engine to 10k many many numberous times with toda valve springs....
Old Aug 10, 2005 | 05:38 PM
nholmes's Avatar
I stand corrected.
Old Aug 10, 2005 | 05:56 PM
SleeperR's Avatar
Toda
Tristan
00-0503
Spawne32
Feb 26, 2011 07:40 AM
rcurry14
Sep 19, 2004 11:05 AM
