FS: OEM ITR Lower Rear Tie Bar
as title says OEM ITR rear lower tie bar for sale. Will fit EG and DC with mods or directly onto an ITR. No hardware just bar.
Located in 818 - Burbank / Glendale area come pick it up.
$50 firm
Pm me
Thanks
Mike
Modified by Viorent GRIP! at 5:17 PM 8/10/2005
$50 firm
Pm me
Thanks
Mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s »</TD></TR><TR><TD CLASS="quote">dont you need to weld two small pieces to make this bar work on dc2(non-type-r) & eg chassis???
and are you selling those two small pieces?</TD></TR></TABLE>
Not exactly sure. I own an EK. All I have is the bar and the bar has two mounting points.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Viorent GRIP! »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
pics?
pics?
yea i believe u are going to need the subframe mounting pieces, but i think these mounting points are part of the subframe on a type r. so i guess unless u plan on cutting them off a type r and welding it on wutever chassis u have, it wont work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cx Son »</TD></TR><TR><TD CLASS="quote">yea i believe u are going to need the subframe mounting pieces, but i think these mounting points are part of the subframe on a type r. so i guess unless u plan on cutting them off a type r and welding it on wutever chassis u have, it wont work</TD></TR></TABLE>
After talking to a friend he says you can make brackets for it, or it'll go on directly to an ITR
After talking to a friend he says you cant make brackets for it, or it'll go on directly to an ITR</TD></TR></TABLE>
should have posted that to begin with. you can use that bar without those two small tabs on the subframe and no honda does not sell those tabs. this will only work on type-r chassis(dc2).
Modified by eg6sir-s at 12:28 AM 8/11/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s »</TD></TR><TR><TD CLASS="quote">should have posted that to begin with. you can use that bar without those two small tabs on the subframe and no honda does not sell those tabs. this will only work on type-r chassis(dc2).</TD></TR></TABLE>
My apologizes. I wasn't familar with the piece or what had to be done to make it work. I just knew that people had them on eg's and dc's. But like I said it can be installed with custom brackets. Or it will dircetly go on to a ITR.
dubs97integ
Jan 8, 2007 02:01 PM
AsiaN_BUILT
Oct 23, 2006 01:16 AM
1995chardx
Northern California (Sales)
27
Jan 30, 2006 09:06 AM
Carpediem291
Apr 5, 2004 12:13 PM
mr.mike
