***** RS*R GT-II and EK HELP!! *****
Wondering if Anyone knows if the RS*R GT-II Exhaust will fit my set up.
'99 Civic Hatchback
'98 Spec JDM ITR B18C Motor
Mugen 4-2-1 Header with O2 Sensor Hole on the Header itself.
Thanks in Advance
'99 Civic Hatchback
Thanks in Advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetEG »</TD></TR><TR><TD CLASS="quote">um if its for your car it will fit.</TD></TR></TABLE>
http://www.rs-r.com/products/exhaust/gt2.php
On their website it's just listed for a "96-'00 HB Civic. But a Normal USDM Civic here has a D-Series motor with D-Series Exhaust system.
I don't know if it's the exhaust system is the same lenght as a Hatchback with a JDM ITR motor and Mugen Header.
the exhaust is made for usdm cars with sohc motors. it will not boltup unless you bought your exhaust in japan.
remember you will always need to modify an exhaust at a muffler shop. if your car has been modified with a bigger motor and different header.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s »</TD></TR><TR><TD CLASS="quote">the exhaust is made for usdm cars with sohc motors. it will not boltup unless you bought your exhaust in japan.
remember you will always need to modify an exhaust at a muffler shop. if your car has been modified with a bigger motor and different header.</TD></TR></TABLE>
not true.
I had this exhaust. I had a single cam on my 96 HB. The exhaust came with a little down pipe looking thing that was removable. I sold the exhaust to a guy who has a b18c5 and a ITR header. he just removed the little pipe and it bolted up right to his header. I've never seen a Mugen header, but as long as the dimensions aren't different than most headers, it should fit
not true.
i think u mite need to get the flange on the exhaust pipe modified to line up with the header or muffler or whatever u wanna do, i got the rsr exmag and i had to cut and reweld the flange on the pipe to line up right. i have a 96 hb with b16 and dc headers
Thanks Spoon98Hatch for the Info. It's good to get info from someone who has run gone thru the same problem.
JDMlyfestyle. Accord to Spoon98Hatch I am not going to need that downpipe unless I am running a SOHC, but I got a DOHC. Thanks for your info as well.
ShinsenTuner
Sep 3, 2017 07:39 PM
fullraceacura
Jun 3, 2005 01:23 PM
REDTOPAlchemy
Sep 19, 2004 09:07 PM
laidave999
Feb 6, 2004 01:24 PM
