Sealing radiator
Old Aug 9, 2005 | 10:48 AM
Silvteg95's Avatar
Default Sealing radiator
I have a little leak at the very top of my radiator, its not a big one just one where a little spary of fluid comes out whats the best thing to patch this with or to seal it up?
Old Aug 9, 2005 | 11:34 AM
chrisnova's Avatar
Default Re: Sealing radiator (Silvteg95)
stopleak or consider soldering it.
Old Aug 9, 2005 | 01:24 PM
Keno20's Avatar
Default Re: Sealing radiator (chrisnova)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisnova &raquo;</TD></TR><TR><TD CLASS="quote">stopleak.</TD></TR></TABLE> This stuff is gold!!
Old Aug 9, 2005 | 01:29 PM
DB8_TEG's Avatar
Default Re: Sealing radiator (Keno20)
ya I used something similar to stop leak when I had a small leak, it was made by prestone and was an aluminized powder, it worked for a few months but then I had to replace the rad but its a good band-aid fix til you have to replace the entire rad if you are strapped for cash.
Lots of guys probably would not recommend using any type of stop leak stuff but I gave it a try.
Old Aug 9, 2005 | 01:53 PM
ROOROWNS's Avatar
Hey man ive seen it work on the $1700 Thin *** aluminum Radiators from lexus. So i think it is alright on my honda. And yours for that matter.
on second thoght is it where the fins meet the end tanks or on the endtank?
Sean
Modified by DA_Black_Hatch at 3:30 PM 8/9/2005
Old Aug 9, 2005 | 03:42 PM
Silvteg95's Avatar
Default Re: (DA_Black_Hatch)
its right where you look down on the radiatornear the cap, not on the top but on the side, and its squirting out on to my heat shield for the headers
Old Aug 9, 2005 | 10:13 PM
Stripped Honda's Avatar
99-0104
Default Re: (Silvteg95)
radiators are cheap why not just spend a hundred bucks because if you burn your motor it will cost alot more then that
Homesickelian
Jun 24, 2007 07:04 AM
hks369
Dec 24, 2006 12:43 PM
vg7z
Jun 15, 2006 08:30 PM
mrlegoman
Jan 14, 2006 01:01 PM
Spec R
Sep 21, 2004 08:56 PM
