Which LSD has 15 bolts for the ring gear?
Old Aug 9, 2005 | 10:10 AM
GS-Rcivic's Avatar
Default ITR LSD is not what it seems ???
Which LSD has 15 bolts for the ring gear? thats the current question now
Hey guys i need your help with this one. Last year buddy of mine got an ITR LSD from a member on ebay for me. It was posted as an ITR LSD and supposedly had a new bearing on it. Cut to the chase, the ring gear broke after the bearing failed so ordered a new one for an ITR and it doesnt fit.
Thought it might have been the wrong one sent but no its the correct one for an ITR. The bolt pattern is different and doesnt fit.
So is there a differece between the ring gear bolt patters for the different year LSDs or between JDM and USDM?? Bout to get a stock diff in there cuz i need to drive the car.
let me know what you guys think, thanks
Modified by GS-Rcivic at 4:14 PM 8/9/2005
Modified by GS-Rcivic at 4:11 PM 8/11/2005
Old Aug 9, 2005 | 10:13 AM
jasonw's Avatar
Default Re: ITR LSD is not what it seems ??? (GS-Rcivic)
Sounds like it could be an OBX. How much did it cost?
Old Aug 9, 2005 | 10:15 AM
sackdz's Avatar
The bolt pattern should be the same for all ITR and GSR diffs. The LS one is different though. Someone let me know if I'm wrong. Is it a limited slip diff or no?
Old Aug 9, 2005 | 10:20 AM
GS-Rcivic's Avatar
Default Re: ITR LSD is not what it seems ??? (sackdz)
yeah its a limited slip and dont think its an OBX one. My friend who got it for me knows about hondas pretty well so it looks like an ITR one but the ITR ring gear doesnt fit for some reason. Got it for $300
Old Aug 9, 2005 | 11:08 AM
Stinkycheezmonky's Avatar
Suspetise...
Pics of each would help.
Old Aug 9, 2005 | 11:12 AM
GS-Rcivic's Avatar
Default Re: ITR LSD is not what it seems ??? (sscguy)
Yeah i know, i'll see if i can have my buddy take pics cuz he has them at his house.
Old Aug 9, 2005 | 02:40 PM
mugenracer's Avatar
I'm just throwing up ideas because i dont really know, but is there a difference in ring gear for 4.4 f/d and 4.785f/d (96spec-v-98spec)???????????
Old Aug 9, 2005 | 03:03 PM
dnatrance's Avatar
Default Re: (mugenracer)
I hade the same problem with mine when I tried to put the 4.7 final drive... the 4.7 final drive ring gear would not fit my diff... The ring gear that fit on my diff had teeth on the inside that rode on exposed gears on the outside of the LSD housing...
let me know if you have the same thing, as far as having small exposed gears on the outside of your diff
Old Aug 9, 2005 | 03:04 PM
dnatrance's Avatar
Default Re: (dnatrance)
it would look exactly like a oem diff, minus the exposed torsen gears (I think thats what they were)..
Old Aug 9, 2005 | 03:15 PM
dnatrance's Avatar
so this is what my setup looks like....
Old Aug 9, 2005 | 07:05 PM
Cheap Bastard's Avatar
New User
From what it sounds like, the diff is definitely not a ITR/CTR diff. Mostly likely an oem lsd from a JDM B16 tranny. Same ring gear but different bolt pattern.
Old Aug 10, 2005 | 04:59 AM
George Knighton's Avatar
H-T Order of Merit
Default Re: (Cheap Bastard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cheap Bastard &raquo;</TD></TR><TR><TD CLASS="quote">Mostly likely an oem lsd from a JDM B16 tranny. Same ring gear but different bolt pattern.</TD></TR></TABLE>
Good thinking!
Old Aug 10, 2005 | 09:49 AM
dnatrance's Avatar
so a b16 lsd has teeth on the inside of the ring gear?
Old Aug 10, 2005 | 11:09 AM
GS-Rcivic's Avatar
The pics will be up this weekend.
I was talking to my buddy today and he said there are 15 bolts for the ring gear and the stock GSR has 10 holes. So does anyone know of an LSD with 15 holes for the ring gear bolts?
Modified by GS-Rcivic at 11:10 AM 8/11/2005
Old Aug 11, 2005 | 10:10 AM
GS-Rcivic's Avatar
Default Re: (GS-Rcivic)
ttt^^^
Old Aug 11, 2005 | 06:14 PM
eg6ajk's Avatar
actually JDM B16As Y21/S21 use 14 bolt and SOHC S20 LSD trannies use 12 bolt LSDs
i found that out on both trannies the hard way, first tranny diff cracked so I got an a GSR diff and of course it didn't work . For the sohc i got 4.9 fd which of course did not bolt up, same issue 12 bolt vs 10bolt FD.
Modified by eg6ajk at 12:37 PM 8/14/2005
Old Aug 11, 2005 | 07:24 PM
Suspetise...
Default Re: (eg6ajk)
Which parts are which parts in that picture, as in, which parts are from which tranny?
Old Aug 12, 2005 | 04:48 PM
GS-Rcivic's Avatar
Default Re: (sscguy)
hmm so nobody knows which LSD has 15 bolts for the ring gear? This cant be something that rare can it?
Am I rich??? Am I?? IM RICH BITCH!!!!
Old Aug 14, 2005 | 09:36 AM
eg6ajk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy &raquo;</TD></TR><TR><TD CLASS="quote">Which parts are which parts in that picture, as in, which parts are from which tranny?</TD></TR></TABLE>
ring gear = JDM Y21 LSD tranny
diff = GSR stock diff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy &raquo;</TD></TR><TR><TD CLASS="quote">hmm so nobody knows which LSD has 15 bolts for the ring gear? This cant be something that rare can it?
Am I rich??? Am I?? IM RICH BITCH!!!! </TD></TR></TABLE>
i just got my another of my old trannies back (S21 LSD Del Slow tranny)
snapped a pic for ya
more pics:
http://hyperducktuning.com/arr/tranny/
Old Sep 20, 2005 | 04:51 PM
memicah's Avatar
If you are sure that the LSD is OEM Honda, it is most likely an EG6 LSD. Does it look like this?
http://im1.shutterfly.com/proc...o5ZOb
PM me if you have any more questions. Hope this helps.
Old Sep 20, 2005 | 04:59 PM
splitime's Avatar
Default Re: (memicah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by memicah &raquo;</TD></TR><TR><TD CLASS="quote">If you are sure that the LSD is OEM Honda, it is most likely an EG6 LSD. Does it look like this?
PM me if you have any more questions. Hope this helps. </TD></TR></TABLE>
That fits the bill for a 15pt lsd. Hopefully that info helps the guy along.
Old Sep 20, 2005 | 06:12 PM
memicah's Avatar
Default Re: (splitime)
yup
Old Sep 20, 2005 | 06:28 PM
Rene M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk &raquo;</TD></TR><TR><TD CLASS="quote">actually JDM B16As Y21/S21 use 14 bolt and SOHC S20 LSD trannies use 12 bolt LSDs
Modified by eg6ajk at 12:37 PM 8/14/2005</TD></TR></TABLE>
That lsd looks like one out of a jdm ZC trans.. I have a Cusco that is the same small pattren.
Old Dec 28, 2022 | 10:05 AM
Corky21's Avatar
Default Re: Which LSD has 15 bolts for the ring gear?
Hey!
revive just because I have ran into issues now and this is the top thread on Google the 15 bolt b series lsd is from a cable y1 transmission they are short geared transmissions that run the small spline 88-91 shafts. The other unique thing is they are the only short ratio transmission with a 4.266 final drive but still manage to achieve similar gearing to hydro b16 transmissions
SilverEk3dr
Transmission & Drivetrain
Jan 25, 2010 02:05 PM
racinjason
Mar 28, 2005 06:56 AM
