could i use b18 harness from 93 teg?
Old Aug 9, 2005 | 09:13 AM
flatblk's Avatar
Default could i use b18 harness from 93 teg?
i wanna use the harness from the b18b is it possible to make it fit my dx crx dpfi? i wanna make it mpfi so i can swap the b18b
Old Aug 9, 2005 | 09:23 AM
mike-y's Avatar
Default Re: could i use b18 harness from 93 teg? (flatblk)
the 93 harness is OBD1, so it will have different connectors than your car's body harness (pre-OBD). You would have to cut off all the connectors on your engine harness, and splice all the wires from the OBD1 harness to your pre-OBD connectors. (or vice versa if you get matching OBD1 plugs for your body harness).
Its a LOT of work, but can be done.
Old Aug 9, 2005 | 09:30 AM
vtecn8ive's Avatar
Default Re: could i use b18 harness from 93 teg? (mike-y)
Nope you will need to convert to MPFI. Which you can't just plug and play. You will have to do some rewiring.
You need to use stock engine harness and modify that. And I believe some that go to the ecu.
This will convert it to MPFI. And after that just hook up the harness to the motor and you are good to go.
-Shane
DaIntegra1991
Feb 5, 2013 07:27 AM
JJGL-EF90
Nov 26, 2010 10:30 PM
accord2civic2prelude
Aug 14, 2009 05:42 AM
jdmekrobot
Mar 13, 2008 12:13 AM
