Cam help
Hey guys, just a question. I have a B18c1 GSR motor in my hatch . here are the specs,
Eagle Crank
Eagle h beam rods
Wiesco Pistons 11.8:1
Portflow Type R head
Crower valve train (Springs retainers)
Ferra Valves
ARP Head Studs
Fidanza Flywheel, Excedy stage 1 clutch.
JDm Type R 4-1 header
Stock B16 Si cams
Eagle Sleeves (30 over)
Heres my question(s), how much power would you speculate i am making, second what would be a good rev limit for this motor, and last what cams do you think i should run for the strip bus still some what streetable. i am more concerned about the track but i still have to drive it every day (unfortunatly :-). This is the Second motor i have built so your help would be great. Thanks.
Modified by mugenhatchie at 5:40 PM 8/9/2005
Eagle Crank
Eagle h beam rods
Ferra Valves
ARP Head Studs
Stock B16 Si cams
crazyitr
May 16, 2003 01:56 AM
