Door Trigger = Dome Lights = ALARM NOT ACTIVATING
Old Aug 9, 2005 | 07:43 AM
eightyHD's Avatar
Default Door Trigger = Dome Lights = ALARM NOT ACTIVATING
Just bought this integra from some dude who used duct tape for electrical tape.
So imagine what the wiring is like.
But regardless, everything still looks intact.
My door triggers that send the -neg output does not show on the guage cluster nor does the dome lights turn on.
He used to have some ghetto *** alarm, and thats been pulled.
Is there some type of sensor that might have blown while he was ghetto riggin his alarm??
Thanks!
Old Aug 9, 2005 | 07:54 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Door Trigger = Dome Lights = ALARM NOT ACTIVATING (eightyHD)
Check the wire connection at the plungers in each door jamb. It's just a standard 0.25" quick disconnect terminal (behind the plastic interior trim panel). Also check to make sure the door plunger is screwed in properly. Either of those will cause the plunger to not work correctly. A body shop left my driver side plunger unscrewed one time and the lights didn't work.
Also remember that the door open dash light only comes on if the ignition is on (unlike Toyotas which work all the time if the door is open).
Old Aug 9, 2005 | 07:58 AM
eightyHD's Avatar
the plungers are working.
i used a light test, and connected it to positive 12v batt.
and tested the wire for ground output, and get connection.
im just wondering if there is a sensor that the wire goes into
jdmeg6honda
Jun 28, 2011 02:40 PM
ccCiviCcc
May 14, 2004 12:22 PM
jspark79
Nov 3, 2002 06:03 PM
GroundZer0
Aug 26, 2002 06:59 PM
5 Liter Eater
Jan 25, 2002 05:32 AM
