1990 crx auto -manual
Old Aug 9, 2005 | 07:37 AM
TypeR15's Avatar
Default 1990 crx auto -manual
i have a 1990 crx automatic...this winter im planning on swaping a b20vtec in it, and coverting it to 5 speed...anyone have any good website with good information??? on the swaps?
Old Aug 9, 2005 | 08:15 AM
Skinflute22's Avatar
if your crx is allready wired for MPFI then the b20 should drop right in granted you get linkage mounts and an ecu.. and as far as convertin to manual all you need is to be sure you get a manual ecu for your engine and get the pedal assemble and shifter and then just get the clutch cable and you should be good to go
Old Aug 9, 2005 | 08:55 AM
vegaskurt's Avatar
Default Re: (Skinflute22)
I got an auto2manual swap guide over at http://www.4gcivic.net, Rywire also has a page that covers the electrical changes you will have to make to the car.
Since you are doing a swap you will be supprised how easy it will be. You wont have to hunt for brackets, mounts and the correct starter.
Old Aug 9, 2005 | 01:43 PM
TypeR15's Avatar
Default Re: (vegaskurt)
thanx nice write up
rice a roni
23
Sep 30, 2022 02:12 AM
91crix
Aug 25, 2009 06:47 PM
thrty8street
15
Feb 8, 2004 09:43 AM
FLCivic
Sep 24, 2003 09:31 PM
MICKSTER
Oct 2, 2002 09:08 AM
