Do I need the knock sensor in this situation?? please help asap!
Old Aug 9, 2005 | 06:51 AM
88_T-Rex's Avatar
Default Do I need the knock sensor in this situation?? please help asap!
Im doing a b20b swap in my crx. I have a jdm B20b and i'm using a PR4 OBD1 Integra LS ecu. I'm using the RyWIre obd0-obd1 conversion harness. the harness has a wire for a knock sensor, but my b20b has no knock sensor (although there is a threaded hole for one). I went to napa to buy one and they told me the crv engine didn't use a knock sensor, but the intwegra ls did. SInce i'm using a ls ecu do I need the knock sensor, or will it work fine without since the b20b never came with one? please help asap.
Old Aug 9, 2005 | 08:33 AM
88_T-Rex's Avatar
bump
Old Aug 9, 2005 | 08:51 AM
Suck my DX's Avatar
Default Re: (88_T-Rex)
bump cuz i wanna know too...i kno that u can remove the function with a chip but with a non modded ecu i have no idea
Old Aug 10, 2005 | 02:57 AM
88_T-Rex's Avatar
bump , anybody know?
Old Aug 10, 2005 | 03:00 AM
Garrett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88_T-Rex &raquo;</TD></TR><TR><TD CLASS="quote">bump , anybody know?</TD></TR></TABLE>
Your PR4 doesn't have Knock sensor unit into the ECU
so no CEL will light up
but
PR4 ECU is not the best for B20B
over 5k rpm you need nmore fuel than b18b
Old Aug 14, 2005 | 11:29 AM
88_T-Rex's Avatar
bump, what is the best to use with a b20b swap then?
huckaboo
Dec 4, 2009 10:34 AM
1.5boosted
Dec 14, 2007 01:45 PM
xwade01
Mar 17, 2005 09:53 AM
hovic
Mar 6, 2005 10:47 AM
rusureboutdat
Jul 28, 2004 10:42 PM
