power steering fluid shooting out the resevoir
Old Aug 8, 2005 | 07:09 PM
Silvteg95's Avatar
Default power steering fluid shooting out the resevoir
I'm hearing a grinding noise from my car and i was wondering if it was because i didnt have enough power steering fluid in the resevoir, which was just below the minimum( supposed to be betweend min.&max.) so as i was turning the wheel and watching the power steering pump there was fluid coming out of the resevoir with the cap on!! what the deeal?!
Old Aug 8, 2005 | 07:36 PM
Silvteg95's Avatar
Default Re: power steering fluid shooting out the resevoir (Silvteg95)
Im guessing that there is too much pressure in the pump maybe and thats why the fluid came pouring out, but im not too sure
Old Aug 8, 2005 | 08:41 PM
vidanator's Avatar
same thing happened to me, but it was during the winter only
Old Aug 9, 2005 | 10:20 AM
Silvteg95's Avatar
Default Re: power steering fluid shooting out the resevoir (vidanator)
really, i have no clue why this happened, but im still thinking its the pressure
Old Aug 9, 2005 | 11:21 AM
Silvteg95's Avatar
ive serached and havent found anything, i really dont want to drive the car now since whenever i turn itll lose fliud and come out the resevoir
Old Aug 9, 2005 | 12:15 PM
95 integra's Avatar
It does kick up alot but with 3 layers of seals Im wondering whats wrong with your cap.
Old Aug 9, 2005 | 12:19 PM
JinteDgraM's Avatar
Default Re: power steering fluid shooting out the resevoir (95 integra)
mine did that after i put in NON honda fluid 2 weeks after I got my car.
Guess who has manual steering now.
Even though I totally shoulda known better, I HONESTLY think there should be a "Your PS will explode if you use ANYTHING but honda PS fluid". Instead of "Only use Honda Genuine Fluids" (That type of phrase is used everywhere).
Wait, i work for honda. Maybe I should sugggest that. haha.
Old Aug 9, 2005 | 04:18 PM
Sam92Teg's Avatar
Default Re: power steering fluid shooting out the resevoir (JinteDgraM)
I imagine alot of people that are not familiar with honda's would buy regular power steering fluid and ruin there pumps. I have never owned a honda before, and am so glad that when I first went to buy power steering fluid I saw some "made for Honda" specific fluid, saved my ***.
Old Aug 9, 2005 | 04:43 PM
95 integra's Avatar
Default Re: power steering fluid shooting out the resevoir (Sam92Teg)
I always used Honda in my GSR, but in the civic I put in shitty $.99 **** and it seems to be working fine.
Old Aug 9, 2005 | 05:33 PM
slomofo's Avatar
GDD Member
Loosen the power steering belt. If you put it on too tight, the fluid will boil.
Old Aug 10, 2005 | 01:18 PM
Pootie's Avatar
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">Loosen the power steering belt. If you put it on too tight, the fluid will boil.</TD></TR></TABLE>
How is that?!
Old Aug 10, 2005 | 01:51 PM
Sifu's Avatar
You need some of those "mAd TiGhT" JDM spoon reservoir covers now
Old Aug 10, 2005 | 02:31 PM
PandaBear's Avatar
It should be the other way around usually. But too tight will force the shaft/bearing to have too much stress on the mating surface and cause heat up.
Use 5mm flex on the long side as guideline on how tight the belt should be.
Old Aug 11, 2005 | 01:01 PM
Pootie's Avatar
ever seen this scenario? My ps was not working and eventually the fluid boiled out. I changed the pump and it worked for about 1 min. then stopped working again and the fluid boiled out once more. any idea what the culprit might be, besides the belt being too tight?
Old Aug 11, 2005 | 02:24 PM
95 integra's Avatar
Default Re: (Pootie)
boiled out? Its hard to boil fluid until it dissappears....are you sure that the pump didnt just pump it all to the rack and that u needed to add more?
Old Aug 11, 2005 | 04:08 PM
slomofo's Avatar
GDD Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pootie &raquo;</TD></TR><TR><TD CLASS="quote">ever seen this scenario? My ps was not working and eventually the fluid boiled out. I changed the pump and it worked for about 1 min. then stopped working again and the fluid boiled out once more. any idea what the culprit might be, besides the belt being too tight?</TD></TR></TABLE>
Maybe your power steering cooler is bad.
Old Aug 11, 2005 | 06:14 PM
Pootie's Avatar
this stuff boiled...started smoking.....I don't think it's the cooler because it stopped working only after 1 minute...okay boiling, i dont' know, but it started smoking and started gushing out from either the pump or the reservoir
AndyD
Feb 8, 2015 09:46 PM
curtie94
Feb 24, 2012 12:38 PM
STi-Thrill
Dec 19, 2011 12:54 PM
vtec.dc2
Aug 1, 2006 08:16 AM
Silvteg95
Aug 1, 2005 06:59 PM
