lsvtec all motor ef
ok as the topis say's here is what my set up is going to be
b16a1 (pr3)
rocket m22 cams and valvetrain with a valve job
custom 4-1 header
b18a1 block
oem bearings
pr3 pistons
ls shot peened rods
jdm s1 trans (looking for a lsd )
and this is going in to my gutted 90 ef hatch tell what guys think
Modified by HondaCivicSiR1 at 4:47 PM 8/11/2005
b16a1 (pr3)
custom 4-1 header
b18a1 block
oem bearings
pr3 pistons
ls shot peened rods
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KhemaraVTEC »</TD></TR><TR><TD CLASS="quote">is this for daily driving or you going to take this to the track? </TD></TR></TABLE> track also is it safe to rev to 9500 rpm's with stock ls rods and ctr's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Christopher M »</TD></TR><TR><TD CLASS="quote">it'll suck </TD></TR></TABLE>and why is that?
because its a general *** post. Ok ls/vtec with good size cams ya its been done and it makes good power only 10,000 other builds just like it drivin around
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Christopher M »</TD></TR><TR><TD CLASS="quote">because its a general *** post. Ok ls/vtec with good size cams ya its been done and it makes good power only 10,000 other builds just like it drivin around</TD></TR></TABLE>well aren't we a negative *****? i was just look for some input on the good and bad on this set up and to get a idea on how much power people are making or did make that is why posted this because i couldn't find what i was looking for when i search
Modified by HondaCivicSiR1 at 2:47 PM 8/9/2005
plan on using arp head ,main studs and rod bolts and maybe even a gsr girdle as for aftermarket rods i know there alot stronger then stock but there also heavier too.does anyone think that stock rods can past 9k rpm?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Christopher M »</TD></TR><TR><TD CLASS="quote">yes and look harder </TD></TR></TABLE>i did look very hard i have spent alot on the computer do research and double checking everything if this is a boring topic then don't post in it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 »</TD></TR><TR><TD CLASS="quote">i did look very hard i have spent alot on the computer do research and double checking everything if this is a boring topic then don't post in it
well obiously u didnt look hard enough, cuz the is a thousand threads on h-t bout ls/vtec's. Urs seems like a basic set up, i think u need to add some things like:
ITR oil pump
ARP head studs
ARP rod bolts
U should have the crank balanced and micropolished(If u have the $$)
</TD></TR></TABLE>well obiously u didnt look hard enough, cuz the is a thousand threads on h-t bout ls/vtec's. Urs seems like a basic set up, i think u need to add some things like:
ITR oil pump
ARP head studs
ARP rod bolts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM DA InTeGrA »</TD></TR><TR><TD CLASS="quote">
ITR oil pump
ARP head studs
ARP rod bolts
</TD></TR></TABLE>i all ready know that i need that stuff if you would have read the whole thread you would have seen that im plan on using arp's stuff! <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 »</TD></TR><TR><TD CLASS="quote">so plan on using arp head ,main studs and rod bolts and maybe even a gsr girdle as for aftermarket rods i know there alot stronger then stock but there also heavier too.does anyone think that stock rods can past 9k rpm?</TD></TR></TABLE> does anyone have a answer to my question about stock rods?
ITR oil pump
ARP head studs
ARP rod bolts
Also here is a good thread to read, tons of info on ls/vtec's
https://honda-tech.com/zerothread?id=501372
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM DA InTeGrA »</TD></TR><TR><TD CLASS="quote">Also here is a good thread to read, tons of info on ls/vtec's
https://honda-tech.com/zerothread?id=501372</TD></TR></TABLE> thanks man
but after reading that what made you go with the lsvtec?
Because if built "properly", a ls/vtec can be one strong *** motor. I have seen plenty of ls/vtec's hit over 215whp. I dont see many gsr's or itr's producing that much power......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM DA InTeGrA »</TD></TR><TR><TD CLASS="quote">Because if built "properly", a ls/vtec can be one strong *** motor. I have seen plenty of ls/vtec's hit over 215whp. I dont see many gsr's or itr's producing that much power......</TD></TR></TABLE>
it all depends on $$$$$$$$$$$$$$$$$$$$$$$$$$$$$ that's what makes it happen.also a jdm itr motor is 200 hp so it wouud take much to make it over 200whp but that's another story that i'm not going to get in to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 »</TD></TR><TR><TD CLASS="quote"> track also is it safe to rev to 9500 rpm's with stock ls rods and ctr's?</TD></TR></TABLE>
Nice, to see a local guy building a monster, but back on topic you don't need to rev m22 cams to 9500 that is over kill. Also I wouldn't risk my motor revving to that high of an rpm with stock ls rods even if you have the arp rod bolts. If you have to second guess yourself its not worth the risk............
Yes it has worked for some people but it usually won't last very long.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM DA InTeGrA »</TD></TR><TR><TD CLASS="quote">ITR motor is 200hp to the crank. Its not 200whp </TD></TR></TABLE>no **** do think i was born yesterday?thanks for your input your really need to worry about your build man since we'll have almost the same set up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke »</TD></TR><TR><TD CLASS="quote">
Yes it has worked for some people but it usually won't last very long.</TD></TR></TABLE> i'm looking in to shot peening my b18 rods what is done to the rod for it to be shot peened?
If you dont need to rev that high up, dont. All it is doing is adding more ware (sp?) and tear to your valvetrain and rotating assembly. And do you have plans to port your head?
