DSM INJECTOR ISSUES***WTF IS GOING ON***
i am having all sorts of issurs concerning my DSM INJECTORS i installed a few days ago...im sure i did everything correct but i will double check in about a hour or so...i even cut ALL the tape covering the wires and followed them all the way back to the box where i cut em and soldered accordingly to every diagram i ever read...but when i checked to see if the injectors were spraying...only 1 of 4 was working...this is by far not enough fuel to run my t3/t4...just a question...what is the point of mounting the resistor box...is it for stability* or does it serve as some type of GROUND*? if i have continuityleading from the solder spots back to the injectors....why might i only have 1 injector spraying ?...when i drive the car it sounds like it wants to die out and starts spudderiing as it seems it is obviously not getting enough fuel..." IF " for example i did wire them correctly...what could be the issue? thx all -swift
turboteg2nv
Dec 2, 2004 03:53 PM
