Crank pulley bolt too tight!
Old Aug 8, 2005 | 04:29 PM
88 dx's Avatar
Default Crank pulley bolt too tight!
I have a 600/700 ft/lb 1/2 drive gun at work. Do you guys think it will get my pulley bolt out. I tried this evening with a long breaker bar and tried to hold the pulley from moving with a punch through one of the pulley holes and against the pan rail. I broke an impact socket and bent the punch and the bolt didn't budge. Any suggestions
Old Aug 8, 2005 | 04:32 PM
slowpokesi's Avatar
Default Re: Crank pulley bolt too tight! (88 dx)
take the flywheel cover plate off and stick a punch in one of the wholes in the flywheel, wedge so its against the tranny, then turn your crank pulley , if you dont have the right punch try a bolt and thread it into one of the holes.
Old Aug 8, 2005 | 04:40 PM
boosted_hatch_216's Avatar
Default Re: Crank pulley bolt too tight! (slowpokesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">take the flywheel cover plate off and stick a punch in one of the wholes in the flywheel, wedge so its against the tranny, then turn your crank pulley , if you dont have the right punch try a bolt and thread it into one of the holes.</TD></TR></TABLE>
most definitely or just stick a screw driver through your flywheel.
Old Aug 8, 2005 | 07:00 PM
91civicEX's Avatar
Default Re: Crank pulley bolt too tight! (boosted_hatch_216)
yea or take the starter out and shove a chisel in there. worked for me
Old Aug 19, 2005 | 07:09 AM
cougar694u's Avatar
Default Re: Crank pulley bolt too tight! (91civicEX)
Is the bolt reverse pattern?
My brother's got an 89 DX hatch with the 1.5l in it and he can't get the bolt out.
Old Aug 19, 2005 | 07:46 AM
user 98292739's Avatar
no its just super hard got ot make sure it doesn t move at all
Old Aug 19, 2005 | 08:26 AM
cougar694u's Avatar
Default Re: (Rexified)
Yikes! He's been at it for days now with breaker bars, air impacts, and it still won't come off. He pulled the start to use a large screw driver to keep the flywheel from turning, but it's still stuck. Any tips, other than a can of gas and a match?
Old Aug 19, 2005 | 08:47 AM
gunslinger's Avatar
From: Where thieves get shot in the face,, texas, usa
Default Re: (cougar694u)
http://www.thetoolwarehouse.net/shop/AP-7809.html
This tool is used the removal of the pulley bolt .
You use a break over bar to hold the bully bolt and the hexagon shape on the pulley is where this tool comes into play.Yo place the break over bar on the bolt and place on the frame of the car and the tool uses the pulley itself to break loose the bolt.
It does take some effort but it will break lose this design is what Honda Dealers use to loosen the bolt.
If you dont want to buy the tool just take to the dealer and have break it loose , then loosly tighten it back up.
Old Aug 19, 2005 | 08:48 AM
dr_latino999's Avatar
I had my car in gear (5th), the brakes mashed to the floor and I took my breaker bar and pushed down with my feet, bam, off it came.
Old Aug 19, 2005 | 08:58 AM
cougar694u's Avatar
Default Re: (dr_latino999)
Thanks guys! I'll try and see how it does, maybe get the tool if I can find it locally.
I'm guess AutoZone doesn't loan that specific tool?
Old Aug 19, 2005 | 10:10 AM
Kryogen's Avatar
remember the most ft/lbs its supposed to run at a max (Z6) will be 126 with a torque wrench, most other Hondas are below the 126 the Z6 ive found is the tightest....so i have been using that #.
just a reminder for when you re-install.
Oh and get a new key and bolt from Honda its like $5 total and they changed the design of the bolt last year or so.
Old Aug 19, 2005 | 10:15 AM
CBURKE's Avatar
Default Re: (Kryogen)
Spray some penetrating fluid in there let is sit for like an hr, then use the impact.
Old Aug 19, 2005 | 10:17 AM
gtturborex's Avatar
when i was in the process of getting my build together i was disassembling my b20 block and could not remove the pulley. i just took it like that to the shop that was sleeving and building the motor for me and they ended up heating up(and breaking it) to remove it. then i'm told i have to buy the new one for them breaking it?
Old Aug 19, 2005 | 10:30 AM
CBURKE's Avatar
Default Re: (gtturborex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtturborex &raquo;</TD></TR><TR><TD CLASS="quote">when i was in the process of getting my build together i was disassembling my b20 block and could not remove the pulley. i just took it like that to the shop that was sleeving and building the motor for me and they ended up heating up(and breaking it) to remove it. then i'm told i have to buy the new one for them breaking it? </TD></TR></TABLE>
lol, that sucks!!!
One of my Honda's (the 88) we were getting ready to take the motor out and when we tried to get the hub nut off (CV axle nut) it would not come off. We tried every thing. My boy that weighs about 250 tried standing on my breaker bar and it broke (the bar). Finely I sprayed some WD40 on there and pulled out my 1/2 driver put the air compressor to 100psi and worked that bitch till it finally broke loose.
1 sLoW hAtCh
Jun 1, 2008 10:07 AM
ILS_Thatstight
Sep 5, 2006 12:10 PM
youngkow
Nov 22, 2002 01:21 AM
BoostedED9
Jun 16, 2002 06:45 AM
