POST WHAT YOU KNOW: Valves, your experiences...
Old Aug 8, 2005 | 04:23 PM
2G0S0R1's Avatar
New User
Default POST WHAT YOU KNOW: Valves, your experiences...
Okay help me out here guys... Ive been aquiring alot of new parts recently to rebuild my head on my GSR. So far Ive got: Gaskets for EVERYTHING, New ITR LMA's, New Valve seals, New Timing Belt, and all fluids. On my car I already have installed the ITR cams/Valvesprings and Adj. Cam Gears. I need to buy some new valves(mine are slightly... shall we say "tweaked") and I dont have any first hand knowledge on them... I will post what I know here from research Ive done the last few months.
1. Flat faced valves could be better for N/A because of a .3 cr bump.
2. Oem/Omnipower/??? wont snap off in the engine like most aftermarket hardened ones because they are a diff alloy.
3. Inconel is desired, like the OEM valves have, because of Better High-Heat protection and smoothness... or a nitride coating of some sort.
4. All valves use OEM valve keepers.
5. Undercut stems improve flow by a small amount (cuz its thinner).
So which brands are KNOWN to bee good. I mean they all LOOK good... REV/Supertech/Crower/Toda/OEM ITR/Portflow/Manley/Skunk2/Omnipower...etc
Which ones really are the **** and why? I am looking for some REAL facts before I go drop this cash on them right now. Ive been workin my *** off on getting my car runnin like a champ... As soon as I pick up a set of these my head is off to Alaniz Technologies for a Stage1 and an Assembly/Rebuild.
Also... I was thinking of using my stock retainers. Im not going to be revving past ~8800 ever and I dont want to worry about Ti ones breaking/wearing down. How many of you with these have had them for more than a year or two without any issues?
Thanks
Old Aug 8, 2005 | 04:34 PM
gsrious's Avatar
very interested... i want to know/learn too.
Old Aug 8, 2005 | 05:44 PM
B20TDC2's Avatar
Default Re: (gsrious)
i have heard good things about supertech's valvetrain. p.m. earl he can help you with your needs
Old Aug 8, 2005 | 10:15 PM
2G0S0R1's Avatar
New User
Default Re: (B20TDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20TDC2 &raquo;</TD></TR><TR><TD CLASS="quote">i have heard good things about supertech's valvetrain. p.m. earl he can help you with your needs</TD></TR></TABLE>
This is correct, Ive talked to Earl and he has decent pricing on these also... Ive heard good things about alot of brands from alot of people... but when I ask them why, they are like ...(mute)...
What valves are you all running up in those heads... c'mon now...
BUMP!
Old Aug 9, 2005 | 05:39 PM
B20TDC2's Avatar
Default Re: (2G0S0R1)
im just running .5mm oversized type r valves in my head
Old Aug 9, 2005 | 06:09 PM
jdmotorsports's Avatar
i have si valves over sized/undercut valves. i havnt dyno'd yet, but the engine pulls for a b18b.
Old Aug 10, 2005 | 06:31 AM
2G0S0R1's Avatar
New User
Default Re: (jdmotorsports)
Nice to hear that OEM is holding up well under boost and in built motors.
Bump.
Old Aug 11, 2005 | 12:04 PM
2G0S0R1's Avatar
New User
Bump, Bump... Bump Bump it up! Thx
Old Aug 11, 2005 | 07:26 PM
95 integra's Avatar
I used modified GSRs in my build with skunk2 valve springs and stock retainers (9k and no problems). I personally think ferreas are the best out there, but then again, they cost more too.
Old Aug 11, 2005 | 07:42 PM
MantisX's Avatar
Default Re: (95 integra)
I keep reading good things about this Earl guy. Does he have a website?
Thanks
MantisX
Old Aug 11, 2005 | 10:13 PM
2G0S0R1's Avatar
New User
Default Re: (MantisX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">I used modified GSRs in my build...</TD></TR></TABLE>
What do you mean by modified exactly, please elaborate.
I am hearing more and more about stock valves. Im sure for N/A they are cool, and alot of people boost on them... but for long term boost or "maybe" even a lil squeeeeze wouldnt something aftermarket be better?
Thanks for the input... keep it coming Honda-Tech, thou art my mentor...
Old Aug 11, 2005 | 11:24 PM
Kendall's Avatar
I believe RLZ uses OEM ITR valves in a lot of the heads they do. If they're using them then that's saying a lot.
Old Aug 12, 2005 | 03:55 PM
B20TDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MantisX &raquo;</TD></TR><TR><TD CLASS="quote">I keep reading good things about this Earl guy. Does he have a website?
Thanks
MantisX</TD></TR></TABLE>
just pm earl on here he can help you with anything you need.
Old Aug 14, 2005 | 11:40 PM
2G0S0R1's Avatar
New User
I got a quote from earl, its cool stuff
Still not sure though... more posts/info required...
THanKs
Old Aug 16, 2005 | 10:48 AM
2G0S0R1's Avatar
New User
BUMP for more info... Who has a built head around here? Cmon now...
BTR_ek9
Engine Machining & Assembly
Oct 12, 2015 05:02 PM
vroomvroomjdm24
Apr 11, 2015 11:15 AM
ludekid4323
Oct 24, 2008 04:56 PM
cdg92eg
10
May 10, 2008 02:17 PM
