how the hell do u run a gsr throttle body on a y8 motor?>!!
Old Aug 8, 2005 | 03:29 PM
igo4bmx's Avatar
Default how the hell do u run a gsr throttle body on a y8 motor?>!!
i've been searching-
everyone says it works...
i tried it, it fits but one problem...
the valve rotor for the tb rotates the opposite direction!
how do u fix this?
Old Aug 8, 2005 | 04:54 PM
ShortbusEK's Avatar
Default Re: how the hell do u run a gsr throttle body on a y8 motor?>!! (igo4bmx)
if by valve rotor im guessing you are talking about the part the throttle cable attaches too.. just switch it out for the one on your stock tb. i know i had to do this when i put the h22 tb on the z6 in my sol
Old Aug 8, 2005 | 05:16 PM
igo4bmx's Avatar
Default Re: how the hell do u run a gsr throttle body on a y8 motor?>!! (EKRboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKRboi &raquo;</TD></TR><TR><TD CLASS="quote">if by valve rotor im guessing you are talking about the part the throttle cable attaches too.. just switch it out for the one on your stock tb. i know i had to do this when i put the h22 tb on the z6 in my sol</TD></TR></TABLE>
the spring on the rotor is on tight... is there any easy way without trying to spread apart a spring and pull the rotor?
Old Aug 8, 2005 | 05:35 PM
pdiggitydogg's Avatar
take your D series wheel (the bronze thing) and swap it onto the gsr tb. You might want to try the spring as well, before just the wheel.
Swapping them will let the cable pull it, as if it were the D's
Axatax
Jun 29, 2013 12:31 PM
purple98ek
May 2, 2007 01:47 PM
EK k kay
Nov 2, 2004 09:57 AM
SLOAZZ95
Dec 12, 2003 01:17 PM
