best intake manifold
Old Aug 8, 2005 | 03:08 PM
sprayin95hatch's Avatar
Default best intake manifold
ok im looking at getting a new manifold since my friend bought mine. i had a obx and it felt like it pulled fine...i was looking at a neat looking one made by a company called aebs, or getting another obx....i though about the skunk2 pro but is this worth 80 more dollars than the other 2?
Old Aug 8, 2005 | 03:45 PM
jdmcoop's Avatar
Default Re: best intake manifold (sprayin95hatch)
blox
Old Aug 8, 2005 | 03:59 PM
Rob Dizzle's Avatar
Default Re: best intake manifold (sleeper-ek)
get the stock b16 intake manifold if you arent going to let us know what you have first.
actually unless you get a custom intake manifold then everything else sucks.
wait, has anyone ever heard of the chrome aebs intake manifold? My couzin told me it was supposed to make more power than the other finish. Im not sure about that, but I would relaly like a chrome one. Now that I think about it, I should get some custom itb's cause they are supposed to give you teh most power. but im not sure if I want to spend the 300 dollars on ebay to get 4 spoon type throttle bodys and hook them all up together.
what does everyone think?
actually why doesnt everyone just say some one liners like "toda!" "AIR" maybe even jg cause jg has only one intake manifold. that would be very helpful.
Old Aug 8, 2005 | 04:15 PM
DelSolDon's Avatar
Default Re: best intake manifold (Rob Dizzle)
yep, since in your sig it says that you got a stock B16, get a stock P30 (B16) manifold. no aftermarket manifold is better on a stock set-up from 0-8000rpm. now if you were running some lumpy cams, then you might look into a different manifold.
Old Aug 8, 2005 | 04:22 PM
RudeBwaiSi's Avatar
Default Re: best intake manifold (DelSolDon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon &raquo;</TD></TR><TR><TD CLASS="quote">yep, since in your sig it says that you got a stock B16, get a stock P30 (B16) manifold. no aftermarket manifold is better on a stock set-up from 0-8000rpm. now if you were running some lumpy cams, then you might look into a different manifold.</TD></TR></TABLE>
Old Aug 8, 2005 | 04:30 PM
jdmcoop's Avatar
Like ?
Old Aug 8, 2005 | 04:32 PM
DelSolDon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeper-ek &raquo;</TD></TR><TR><TD CLASS="quote">
Like ?</TD></TR></TABLE>
AEBS for cheap all motor, AIR for expensive all motor
take your pick
Old Aug 8, 2005 | 04:40 PM
topspeed86's Avatar
get your manifold extruded honed
Old Aug 8, 2005 | 05:03 PM
Rob Dizzle's Avatar
Default Re: best intake manifold (topspeed86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by topspeed86 &raquo;</TD></TR><TR><TD CLASS="quote">get your manifold extruded honed </TD></TR></TABLE>
why?
if you are going to spend 300-600 bux to get a manifold extruded and its a pos intake manifold. spending money on something that was designed and mfg'd properly from the get go will usually be better
Old Aug 8, 2005 | 07:58 PM
my setup will be 11.1:1 comression , stage 1 cams, and nitrous.
Old Aug 8, 2005 | 08:29 PM
asubennett's Avatar
Default Re: (sprayin95hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob Dizzle &raquo;</TD></TR><TR><TD CLASS="quote">
why?
if you are going to spend 300-600 bux to get a manifold extruded and its a pos intake manifold. spending money on something that was designed and mfg'd properly from the get go will usually be better</TD></TR></TABLE>
Since when was extrude honing 300-600 dollars?
Honestly if you are going to run nitrous the AEBS would be a good choice for you because it comes pretapped for direct port on the back of the manifold. It also has similar design to your OEM B16 manifold with more plenum volume.
Old Aug 8, 2005 | 08:46 PM
Rob Dizzle's Avatar
Default Re: (asubennett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">Since when was extrude honing 300-600 dollars?
Honestly if you are going to run nitrous the AEBS would be a good choice for you because it comes pretapped for direct port on the back of the manifold. It also has similar design to your OEM B16 manifold with more plenum volume. </TD></TR></TABLE>
http://www.modernperformance.c...shtml
they want 400. extrude hone doesnt have pricing on their website.
im pretty sure a h-t member on here that had a lightly modified itr did the process to his itr intake manifold and he had a bit more horse power.
there are a **** load of threads on how having smooth intake manifold runners isnt the best idea.
and I was joking about the b16 intake manifold. wtf would you get one of those when you can get itr intake manifolds, blox, and aebs manifolds?
Old Aug 8, 2005 | 10:12 PM
asubennett's Avatar
Default Re: (Rob Dizzle)
Becasue the B16 manifold will actualy hold its own againt an ITR manifold until 8000rpm plus. But now that I know he is using nitrous he should really look at AEBS.
That is a crazy price quote for extrude honing a manifold. Nothing wrong with a smooth manifold. It is more the intake ports on the head that you do not want smooth.
Old Aug 8, 2005 | 10:19 PM
HondaIntegraR's Avatar
omniman made some awesome power with his extrude honed manifold, forgot what it was.. but it might be an aebs... not 100% sure tho
Old Aug 8, 2005 | 10:57 PM
Rob Dizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett &raquo;</TD></TR><TR><TD CLASS="quote">Becasue the B16 manifold will actualy hold its own againt an ITR manifold until 8000rpm plus. But now that I know he is using nitrous he should really look at AEBS.
That is a crazy price quote for extrude honing a manifold. Nothing wrong with a smooth manifold. It is more the intake ports on the head that you do not want smooth.</TD></TR></TABLE>
where can you get it less than 400 for an intake manifold?
what does hold its own mean?
Old Aug 9, 2005 | 04:07 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob Dizzle &raquo;</TD></TR><TR><TD CLASS="quote">what does hold its own mean?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1259496
Old Aug 9, 2005 | 05:47 AM
asubennett's Avatar
Default Re: (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=1259496</TD></TR></TABLE>
Thanks man. :-)
Old Aug 9, 2005 | 03:38 PM
topspeed86's Avatar
Extrude Hone does a great job worth the money
Old Aug 12, 2005 | 11:10 AM
Rob Dizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1259496</TD></TR></TABLE>
damnit, why did you have to go back in time and post that?
thats pretty cool though, I didnt know that IM was that good.
real world &gt; theory
Old Aug 12, 2005 | 11:17 AM
noboostedEGo's Avatar
Hell yeah I was about to start looking for that thread, it pleasantly suprised me also.
Old Aug 13, 2005 | 04:45 AM
vti444's Avatar
i wish i had looked into this more before i got ek9 i/m fitted to my b16. been told my oem b16a i/m would have been much better option on my daily driver
does anyone have any info on the jun i/m which has been discontinued now ? heard it was good but dont know if thats bullshit or not
shutdown
13
Jul 23, 2005 03:19 PM
01itr320
Feb 23, 2005 09:34 AM
Travis922
Dec 11, 2004 05:17 PM
BrokdwnCrx
18
Nov 19, 2002 09:53 PM
