swapping from b18a1 to b16a2
im trading my ls for my friends b16a2 and i was just wondering what all i will need to put it in my crx. which ecu (he doesnt have the right one) and where i could get a harness for the engine or do i use the stock crx one.
somebody please give me some help with this we're going to be doing it this week.
The stock CRX wiring harness will work, you'll just have to add the wiring for VTEC, a quick search will turn up plenty of info, it's not hard.
As far as the ECU, you can either use a PR3 or PW0. Another option is to get the stock PM6 ecu to control the VTEC solenoid through the AC clutch line, that makes the wiring a little easier and you can do a lot more tuning with the PM6. You also already have the ECU, you don't have to go looking for one and spending too much.
im not too worried about the vtec right now i just want to get it at least running so its drivable. ill end up putting just a vtec switch for vtec sometime.
the mounts for a b18 and b16 are the same right?
sweet. o and it completely possible to just take his motor and put it in my car in one day? we're going to trade the complete engine harness and everything so we can do it quicker. sucks for me cuz i already shaved my engine bay
Should be no problem to have running in a few hours. It's just plug and play if you're not worried about VTEC. If you're swapping the whole harness, it's like 3 plugs, some hoses and the mounts, axles, etc. No sweat.
i think were just going to trade everything... like mounts, linkages and harness just so its really simple to swap. ive got some **** in and on my LS but im gettin a pretty good deal i guess for the b16a2.
its probly gona be a bitch still cuz ive never takin off axles or any of that stuff. o well. learning experience. still kinda scared to try and get it in 1 day.
The only difficult part might be getting the axle nuts off, it can be a ***** without an impact gun. And getting The Bitch Pin out of the shift linkage can be tough if it wasn't done recently. Overall though, not a big deal. Just take it a step at a time and have a manual handy if you can.
i always do swaps without takin the bitch pin and the axles out. if you break the lower ball joint you can swing the whole hub out and the axle with it. then u can unbolt the shift linkage and if ur carefull u can manuever it out with the engine. its a lot easier to get that stupid pin out when the engine is out.
yeh not trading engines anymore, im trading him my car for his 88 crx si and his 91 hf. gona put the b16 in the hf and sell the 88. i think im gettin a pretty damn good deal.
monstercrx666
Jun 15, 2004 11:40 AM
