VAFC fuel and air adjustments per rpm..
This is probably a simple question for some people with the product but... does anyone know if the ratio adjustment is alternated and preprogrammed for the diferent gear @ rpm, or is it soley based on rpms itself?
btw... this is generalized, if all do then cool, if not may i ask which one does?
Apex AFC's are not preprogrammed for your car. They are not just plug & play systems. You can really break something tuning with this product if dont you know anything about air/fuel ratio at each rpm for both high&low throttle percentages.
The default setting when you first turn it on, will be for a 6-cylinder nissan (on the SAFC).
i never said it was preprogrammed for my car, im saying , can we pre program the way it operates in each gear...
