B16A2 with ERL's Superdeck II pictures
Old Aug 8, 2005 | 01:37 PM
jdmcoop's Avatar
Default B16A2 with ERL's Superdeck II pictures UPDATE
FINISHED BLOCK ON PAGE 3 & Nitrous manifold (updated 9-3-05)
Modified by sleeper-ek at 8:26 AM 9/4/2005
Old Aug 8, 2005 | 01:58 PM
mtber's Avatar
Default Re: B16A2 with ERL's Superdeck II pictures (sleeper-ek)
Old Aug 8, 2005 | 02:07 PM
DIFFUT'S INC.'s Avatar
Default Re: B16A2 with ERL's Superdeck II pictures (mtber)
THATS WHAT I LIKE TO SEE
Old Aug 8, 2005 | 02:54 PM
BigBodySmith's Avatar
what are the specs???
Old Aug 8, 2005 | 03:15 PM
jdmcoop's Avatar
thanks alot for the comments. its being bored out to 84mm and i'm installing a b18c crank. i'm going to run 11:1 cp pistons, manley forged rods, erl's five point main girdle, arp head and main stud kit and i'm going to spray 100 shot direct port.
as far as the head just skunk2 stage 2 cams, skunk2 cam gears, valves, springs, and retainers. hoping to post some dyno numbers and track times before the summer ends.
Old Aug 8, 2005 | 04:07 PM
PHO-SHIZZLE's Avatar
How much does ERL charge to do Superdeck/deckplate blocks?
Old Aug 8, 2005 | 04:12 PM
MR.M's Avatar
Default Re: B16A2 with ERL's Superdeck II pictures (PHO-SHIZZLE)
Old Aug 8, 2005 | 04:17 PM
jdmcoop's Avatar
I think its either $1400 or $1450 but thats the box to ship it in and shipping back to erl, sleeves, deckplate which makes it closed deck, cylinder hone, line hone, and acl main bearings. the finished product is beautiful (no seams between the sleeves, and the deck is honed by hand). mine should be done tommorrow besides the cylinder hone because i'm still waiting on my pistons to show up but i will have more pictures tommorrow.
Old Aug 8, 2005 | 07:19 PM
spooncivic1's Avatar
should have gotten a b18 block and stroked it to 95mm
Old Aug 9, 2005 | 11:39 AM
jdmcoop's Avatar
Default Re: (spooncivic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooncivic1 &raquo;</TD></TR><TR><TD CLASS="quote">should have gotten a b18 block and stroked it to 95mm </TD></TR></TABLE>
i'm building the motor for revs. generally theres two ways of making horsepower, torque and rpms. the honda b-series aren't really known for there torque like the k24's are. if i was wanting torque i would go that route. also if i went with a b18 stroked with 95mm and reved it to 9500 rpms the pistons speed would be ridiculous. instead to get that little bit more torque i had it bored to 84mm. i guess its all about your personal opinon though.
Old Aug 9, 2005 | 12:03 PM
jdmcoop's Avatar
here are some more pictures. it still needs to be cylinder honed and line honda but here are some new updated pictures.
Old Aug 9, 2005 | 12:49 PM
indomotor's Avatar
Old Aug 9, 2005 | 12:56 PM
2k.civic.si's Avatar
Default Re: B16A2 with ERL's Superdeck II pictures (indomotor)
i always wondered about a setup like this....do you now need 2 head gaskets? how does the deckplate seal to the block? is there any special machiene work that needs to be done to the head....and do you need a longer timing belt? or does a b18 belt fit?
curiosity
Old Aug 9, 2005 | 12:59 PM
Phatch99's Avatar
Default Re: B16A2 with ERL's Superdeck II pictures (2k.civic.si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">i always wondered about a setup like this....do you now need 2 head gaskets? how does the deckplate seal to the block? is there any special machiene work that needs to be done to the head....and do you need a longer timing belt? or does a b18 belt fit?
curiosity </TD></TR></TABLE>
Would like to know also...
Old Aug 9, 2005 | 02:05 PM
jdmcoop's Avatar
all questions welcome. starting with the deckplate; they took measurements of the deckplate dimensions then made a cnc program that takes out just enough material around the sleeves and block for the deckplate to be pressed in. it is an exact fit, pretty amazing. then between the block and deckplate is a head gasket (included in the price) with locktite sealant. you still use your normal head gasket between the deckplate and the head.
i will be running a b18 timing belt and an it-r oil pump (not a must, just doing it for the rpm's i'm want to run) and as far as the head it bolts on just like oem. thats whats so good about erl's superdeck systems.
Old Aug 9, 2005 | 02:15 PM
i take it your using custom length rods?
Old Aug 9, 2005 | 02:25 PM
LBCek9's Avatar
Default Re:
goood stuff!
Old Aug 9, 2005 | 02:27 PM
jdmcoop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">i take it your using custom length rods? </TD></TR></TABLE>
no, i'm sticking with rods for a b18c. i was thinking about that too but jeff at erl said i can stick with that to save some headache. now if i wanted a custom rod lenghth they can deck the deckplate to whatever height that the customer wants.
Old Aug 9, 2005 | 02:35 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
SICK WORK BUT DECKPLATES IN MY OPINION GOOD LUCK WITH THE BUILD
Old Aug 9, 2005 | 06:17 PM
JDM Vision's Avatar
Default Re: B16A2 with ERL's Superdeck II pictures (HOOKUPS)
very nice build
Old Aug 9, 2005 | 08:54 PM
Fkned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">SICK WORK BUT DECKPLATES IN MY OPINION GOOD LUCK WITH THE BUILD</TD></TR></TABLE>I would agree w/you on the deck plates I've seen in the past,but this one is ****.I just saw one at FSM in Delaware for a Hot Rod class car/Josh Turner and it was beautiful work flawless,imo. ERL will deff get my sleeving work in the future.
Old Aug 9, 2005 | 09:00 PM
Quitripin's Avatar
Nice and clean........Loving the girdle, pretty beefy
Old Aug 10, 2005 | 09:18 AM
DYNO-PRO
Default Re: B16A2 with ERL's Superdeck II pictures (Quitripin)
OH YES I DEFF AGREE THE WORK is awesome i just dont use deckplate motors but erl
Old Aug 10, 2005 | 09:41 AM
PURPLETERROR aka BIGMATT's Avatar
Looks awesome, cant wait to se everything when its finished
Old Aug 10, 2005 | 09:58 AM
.nate's Avatar
You said that you're going to be using a gsr crank... what about rod length?
EDIT: I looked at your post down the page and saw you're using GSR spec rods... you said you want to keep piston speeds down at high revs, but won't this combo put you in the same shoes as just running a b18c block since you're loosing the b16 r/s ratio?
