Went to the track for the first time with new setup on street tires ...
I got some good times out of the car and I am quite happy. The times ran consistant all night but I couldnt drop my 60 ft at all on these street tires
... But anyway the car is a 90 si hatch full interior (sunroof) and full weight only minus a/c. All night I ran consistant 11.91-11.96 (traps between 124.9-126.4 mph) but what sucked was no matter how much I heated the radials or reduced pressure, if I rode the clutch so it would hook my 60's wouldnt get out of 2.0's... I dunno guess I need more practice but I was happy with my consistantcy and I had fun. Cant wait to get it caged and race in some turbo 4 classes.
The radials are 225/50/15's ... The car is an 84mm Ls block with eagle/arias combo with crower valve-train in the head including turbo cams. I tach the motor to 8200 with my current low boost but looking to tach to about 9000 with about 30 psi for slicks
i have seen guys put their tire pressure up to like say 38 psi see what that does i mean for street driving if u drive at higher speed they say to put the pressure up
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20turboic »</TD></TR><TR><TD CLASS="quote">The radials are 225/50/15's ... The car is an 84mm Ls block with eagle/arias combo with crower valve-train in the head including turbo cams. I tach the motor to 8200 with my current low boost but looking to tach to about 9000 with about 30 psi for slicks
what turbo you running?
</TD></TR></TABLE>what turbo you running?
A fatty one
hahah How many CFMs does it flow and how many lbs were you running @ the track? Keep us updated with times once you get slicks~! O yea if you got any engine shots, post em up!!! Nice times!
Blaze
A fatty one
hahah How many CFMs does it flow and how many lbs were you running @ the track? Keep us updated with times once you get slicks~! O yea if you got any engine shots, post em up!!! Nice times!Blaze
I am running Pheonix Turbo's "Blowzilla" it flows 65lb/min I believe ... I was running 18-19 psi on pump for these runs. I am going to get some engine shots up soon ... I will post them here and in FI forum.
