went to the track....pretty unhappy so far
stripped 89Si
B16A SiR
SiRII intake manifold
B18A throttle body
saturated injectors
ITR cams
smashed DC sports 4-2-1
heated O2 sensor
top secret cat
2.25 "exhaust
stock PW0
the timing was retarded, bad plugs, needs new wires, needs a new fuel filter, bad tires
hopefully i can have all this fixed by next time i go...
R/T .625
60 2.398
330 3.389
mph 75.71
1000 12.469
1/4 14.850
mph 94.54
B16A SiR
B18A throttle body
saturated injectors
ITR cams
heated O2 sensor
top secret cat
2.25 "exhaust
stock PW0
R/T .625
60 2.398
330 3.389
mph 75.71
1000 12.469
1/4 14.850
mph 94.54
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus »</TD></TR><TR><TD CLASS="quote">the timing was retarded, bad plugs, needs new wires, needs a new fuel filter, bad tires
hopefully i can have all this fixed by next time i go...</TD></TR></TABLE>
I'd be unhappy too if I went to the strip w/o performing all the above listed maintenance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus »</TD></TR><TR><TD CLASS="quote">stripped 89Si
B16A SiR
B18A throttle body
saturated injectors
ITR cams
heated O2 sensor
top secret cat
2.25 "exhaust
stock PW0
R/T .625
60 2.398
330 3.389
mph 75.71
1000 12.469
1/4 14.850
mph 94.54</TD></TR></TABLE>
Perform the maintenance and drop the 60ft time to around 2.2 and you should see better numbers.
B16A SiR
B18A throttle body
saturated injectors
ITR cams
heated O2 sensor
top secret cat
2.25 "exhaust
stock PW0
R/T .625
60 2.398
330 3.389
mph 75.71
1000 12.469
1/4 14.850
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keith P »</TD></TR><TR><TD CLASS="quote">
dude those are horrible times...stock b16 in a full interior 89 is faster than that
why are u driving ur car around in that condition anyway?
with a 94.5 trap speed...u must have been spinning those tires for a hot second...remember its not a burnout contest
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">dude those are horrible times...stock b16 in a full interior 89 is faster than that
with a 94.5 trap speed...u must have been spinning those tires for a hot second...remember its not a burnout contest</TD></TR></TABLE>
dood, i knew..i was elsewhere when i did that,, i realized all those things are wrong, and i am working hard on fixing it all. I live in a town where all the fast cars are american.....it is hard to get parts here..they sell accell 8MM wires at autozone, but not for hondas.....go figure huh...when the catalog lists them as something they make...okay rant over
I live in a town where all the fast cars are american.....it is hard to get parts here..they sell accell 8MM wires at autozone, but not for hondas.....go figure huh...when the catalog lists them as something they make...okay rant over</TD></TR></TABLE>
Why don't you make use of the internet and order the parts you need online.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus »</TD></TR><TR><TD CLASS="quote">the timing was retarded, bad plugs, needs new wires, needs a new fuel filter, bad tires</TD></TR></TABLE>
90 Si
only upper dash and the 2 front seats
1st gen B16A
S1 Transmission
Open Header
Autozone Rice Isle Intake with Genuine K&N
205/50/15 azenis Sports
15.1
Same car
New Irridium Spark Plugs
New OEM fuel pump
New Oem Fuel filter
New OEM distrbutor
MSD super conductor plug wires
Set timing
170/70/13 Khumo 4 for $100 tires
14.6
90 Si
1st gen B16A
S1 Transmission
Open Header
15.1
Same car
New OEM fuel pump
New Oem Fuel filter
New OEM distrbutor
Set timing
14.6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 »</TD></TR><TR><TD CLASS="quote">
Why don't you make use of the internet and order the parts you need online. </TD></TR></TABLE>
it sucks to wait a day or two, or a week.. but.. its worth it in the end. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp »</TD></TR><TR><TD CLASS="quote">
it sucks to wait a day or two, or a week.. but.. its worth it in the end. good luck</TD></TR></TABLE>
It sucks when you have to pay 2x as much for shipping because you are in the middle of the Pacific Ocean and a company will only ship 2nd day air to you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus »</TD></TR><TR><TD CLASS="quote">they sell accell 8MM wires at autozone, but not for hondas.....</TD></TR></TABLE>
Good. Get some OEM Honda plugs, wires, cap and rotor. Anything else is probably junk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 »</TD></TR><TR><TD CLASS="quote">Good. Get some OEM Honda plugs, wires, cap and rotor. Anything else is probably junk.</TD></TR></TABLE>
I agree. Where exactly are you located anyways?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson »</TD></TR><TR><TD CLASS="quote">I agree. Where exactly are you located anyways?</TD></TR></TABLE>
so why do soo many seriously modded cars have aftermarket ignition systems?
why did my car run better when i had accel wires on it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson »</TD></TR><TR><TD CLASS="quote">Where exactly are you located anyways?</TD></TR></TABLE>
Charlotte, NC. I am not a hick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus »</TD></TR><TR><TD CLASS="quote">so why do soo many seriously modded cars have aftermarket ignition systems?
why did my car run better when i had accel wires on it?</TD></TR></TABLE>
If you think that "Race cars have it, so I need it" is a good reason, you're a ricer. I think that's part of the definition, anyway. You don't have 30psi mixed with ethanol coming into the combustion chamber at 9000rpm, do you? Then don't worry about it.
If your car ran better with Accel wires, that means whatever they replaced was some OLD *** wires. Or it was in your mind. An air/fuel mixture is either ignited or it isn't. And I assure you the wires have VERY little say in whether that happens or not. Magnacore is about the only aftermarket brand that is worth anything, but even then, you better have something badass to require those. I'd rather get some $50 OEM wires that work better than some $150 Accel Super 20mm wires. Quality, not quantity...
Read this: http://www.sdsefi.com/techcomb.htm
Yeah, any time you remove your old worn out stuff and replace it with new you are gonna feel a difference. Now, try maybe opening a summit mag or something like that. They have good shipping and the prices aren't so bad. Leave the Honda ignition alone. Unless you are gonna start drag racing your stock is fine. Some nice MSD wire's wouldn't hurt. But if I were you i would not race until you have that done. You really could mess something ells up.
Well this week
I
Installed JGedelbrock intake manifold, GSR throttle Body, Adjustable FPR, 99 Si Stock Header, changed the oil, changed the spark plugs, changed the wires, new 02 sensor....it "feels" a lot faster, it really needs a tuned ECU, and a better clutch
I finally decided to test the thing out....and well some weight redux happened.....i heard a whistle and pop......there goes the sunroof!!!!! and my GF said there was sparks....!!!!
DAMMIT>>>> where am i going to get something to keep the rain out
this is the suxors
I
this is the suxors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus »</TD></TR><TR><TD CLASS="quote">Well this week
I
this is the suxors</TD></TR></TABLE>
That does suck, at least your car is fast and fun to take out on sunny days, I had my car in the driveway for over a year
Life's not over man, if the sunroof is too fucked to fix the mechanism, just take the metal plate and rivet it in (make sure to use some silicone seal!), or do the same with some Lexan (or any material for that matter) cut to spec.
And by the way, you really should upgrade that ECU, maybe just to chipped P28 with a DOHC VTEC map but with the addition of an aftermarket intake manifold and ITR cams I highly recommend it.
I
this is the suxors</TD></TR></TABLE>That does suck, at least your car is fast and fun to take out on sunny days, I had my car in the driveway for over a year
Life's not over man, if the sunroof is too fucked to fix the mechanism, just take the metal plate and rivet it in (make sure to use some silicone seal!), or do the same with some Lexan (or any material for that matter) cut to spec. And by the way, you really should upgrade that ECU, maybe just to chipped P28 with a DOHC VTEC map but with the addition of an aftermarket intake manifold and ITR cams I highly recommend it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jedubz »</TD></TR><TR><TD CLASS="quote"> just take the metal plate and rivet it in (make sure to use some silicone seal!), or do the same with some Lexan (or any material for that matter) cut to spec. </TD></TR></TABLE>
Yeah, I'm pimping an aluminum sunroof "patch".
Pop rivets and silicone.
I've seen carbon fiber sunroof plugs, but they were a bit pricey.
dammit it was cloudy today, so i taped some plastic over it......the plastic collapsed.....and about 2 gallons of water got on my seat
.......so i used a lot more plastic and tape.....the water is out......the car looks like crap.........so tomorrow..if i can get some money and ****....i will have to do something about this.......i already spent 442 to get the power back on this week.....you think i can do it with $7
I was a bit nicer in my previous post because I just assumed you were a newb.. But this was a just plain was a stupid move.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus »</TD></TR><TR><TD CLASS="quote">dammit it was cloudy today, so i taped some plastic over it......the plastic collapsed.....and about 2 gallons of water got on my seat
.......so i used a lot more plastic and tape.....the water is out......the car looks like crap.........so tomorrow..if i can get some money and ****....i will have to do something about this.......i already spent 442 to get the power back on this week.....you think i can do it with $7</TD></TR></TABLE>
You can do it for free, just be creative. If you're so damn intent on cheaping it and not doing it right for $50, just go get some wood from a construction site and cut it by hand, some spray paint, some silicone glue (or just any window sealer if you're so ghetto) and if you're lucky borrow a pop rivet gun from a friend.
But seriously, just do it right.
.......so i used a lot more plastic and tape.....the water is out......the car looks like crap.........so tomorrow..if i can get some money and ****....i will have to do something about this.......i already spent 442 to get the power back on this week.....you think i can do it with $7</TD></TR></TABLE>You can do it for free, just be creative. If you're so damn intent on cheaping it and not doing it right for $50, just go get some wood from a construction site and cut it by hand, some spray paint, some silicone glue (or just any window sealer if you're so ghetto) and if you're lucky borrow a pop rivet gun from a friend.
Sell your damn Car, and the engine.
But a civic sedan, or the cheapest Honda you can get.
Why get into an expensive hobby if you're broke?
And why modify your car when you can't pay your power bill?
No offense, just some advice.
Prioritize.
.......so i used a lot more plastic and tape.....the water is out......the car looks like crap.........so tomorrow..if i can get some money and ****....i will have to do something about this.......i already spent 442 to get the power back on this week.....you think i can do it with $7</TD></TR></TABLE>Sell your damn Car, and the engine.
Prioritize.
