97 Accord EX 4 cyl VTEC - P0401?
Old Aug 8, 2005 | 06:28 AM
tom10e's Avatar
Default 97 Accord EX 4 cyl VTEC - P0401?
Hi,
P0401 code...
I have cleaned vacuum lines and EGR valve ports.
Code back @ 60 miles and 92 miles second time, CEL was reset each time.
Before I throw a new EGR valve in (which seems to be working as it should, it is seated and moves when vacuum source is applied) does the solenoid valve throw this code also or does it have its own. I have vacuum up to the solenoid valve but have not noticed any vacuum at EGR and the line is clear. When is the solenoid valve supposes to operate and does it use 12v.
Thanks, Tom
97 Accord 180k
87 CRX 152k
Old Aug 8, 2005 | 02:11 PM
Chiovnidca's Avatar
Default Re: 97 Accord EX 4 cyl VTEC - P0401? (tom10e)
The solenoid could be the problem. Does the vacuum line to the egr valve show vacuum when you raise the rpms to about 1500-2000? If not, does the ecu energize the egr solenoid under the same conditions? (the engine needs to be warmed up to)
Old Aug 8, 2005 | 03:49 PM
bill-71SS's Avatar
Default Re: 97 Accord EX 4 cyl VTEC - P0401? (Chiovnidca)
a 401 code will most likely be the egr ports clogged,look under youf fuel rail and you will see a plate,take it off and clean the clogged ports out.
D-Atk
Aug 21, 2019 03:35 PM
Doug Winsor
Aug 26, 2015 12:40 PM
hecubus
Feb 21, 2014 04:47 PM
hfbellosa
Sep 27, 2013 06:05 AM
NEHOG
Sep 4, 2011 03:29 PM
