Did b18c header will clear B20 block? Fit under the b20 oil pan?
Old Aug 8, 2005 | 05:07 AM
jt-sport's Avatar
Default Did b18c header will clear B20 block? Fit under the b20 oil pan?
Im just currious if im have a B18C header, then im going to put b20 block on this motor , will the header clear the B20 oil pan?
I think b20 block was a bit taller right ?
Old Aug 8, 2005 | 11:57 AM
DOHCtorTHRUST's Avatar
Default Re: Did b18c header will clear B20 block? Fit under the b20 oil pan? (jt-sport)
the b20 block is not taller, the only difference between a b20 and a b18a/b is the bore size. there are few differences but for the most part, they are the exact same thing. so the b18 header will clear.
Old Aug 9, 2005 | 06:42 AM
jt-sport's Avatar
thanks DOHC
Old Aug 9, 2005 | 07:15 PM
torqueMONSTER's Avatar
Default Re: (jt-sport)
yea i got a b20. gsr headers clear fine
Old Aug 10, 2005 | 06:09 AM
jt-sport's Avatar
thanks palls, but how about b16 block compare to b18 block ??? still the same height to ??
Old Aug 11, 2005 | 06:41 PM
i believe the b18 is taller than the b16. the b18 to b20 on the other hand is the same height but different bore
silentdeath12886
Aug 1, 2007 08:34 AM
Edu VTi
Oct 18, 2006 12:04 PM
jt-sport
Aug 8, 2005 05:19 PM
RCautoworks
Jun 3, 2005 10:24 AM
