sqeaky cutch pedal
Old Aug 7, 2005 | 09:50 PM
krnboynemesis's Avatar
Default sqeaky cutch pedal
The clutch pedal (not the actual clutch) on my 01 GSR is sqeaking. Just need some lubrication?
Old Aug 7, 2005 | 11:53 PM
TunerN00b's Avatar
Default Re: sqeaky cutch pedal (krnboynemesis)
Bump, mine does this too. 00 gsr.
Old Aug 8, 2005 | 12:06 AM
seejay's Avatar
Default Re: sqeaky cutch pedal (TunerN00b)
whoa... another bump...so does mine
Old Aug 8, 2005 | 12:44 AM
Eddiebx's Avatar
if it squeeks, spray some lube on the spring and joint area
Old Aug 8, 2005 | 01:16 AM
inzane's Avatar
might be your throw out bearing mine squeaks also I was told that the throw out bearing is most likely it
Old Aug 8, 2005 | 09:53 PM
Default Re: (inzane)
hrmm cool cool. Now I just gotta decide if I'm not gonna be lazy and do something about it.
Old Aug 11, 2005 | 07:46 AM
Integra_chick95's Avatar
I don't think that it would be the throw out bearing because mine squeaks too, when I replaced the clutch a few months ago I replace the thow out bearing also. Still squeaks. Don't know what to do...
Old Aug 11, 2005 | 09:05 AM
B18C_DD's Avatar
Default Re: (Eddiebx)
Lube sprayed and fixed the problem for about a day. Started it up this morning with a squeak!
Old Aug 11, 2005 | 10:24 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: (B18CDD)
If it's not the throwout bearing, then it's most probably something simple with the moving parts of the clutch pedal/cable. Just lube that up and it should be fine. Other than that, there are really no moving parts.
Old Aug 11, 2005 | 02:49 PM
eightyHD's Avatar
on the tranny, pull the boot off the arm that pushed the clutch/throwout bearing,
get soem general grease, and light application of grease, pump clutch w/engine off, regrease til the ****** stops squeaking.
Old Aug 11, 2005 | 03:32 PM
projectTeG's Avatar
Default Re: (eightyHD)
lube the pedal and the pivot point thats on the slave cylinder for the clutch fork
hcs1jimmy
Apr 19, 2011 04:12 PM
phyzJunkieCivic
Jun 29, 2006 10:41 PM
maxogsr
Jun 22, 2005 06:46 PM
doublejz
Mar 9, 2004 01:19 PM
tylerdurden
Mar 26, 2003 06:41 PM
