IM WORKING ON MY CAR RIGHT NOW NEED HELP!
ok, im currently trying to install a short throw shifter, i can drop the whole shift part out. but the exuast is in the way. Im working right near the cat. main question. How do i remove the hook on the exuast from the rubber that holds on to it? its a 97 civic hx.
PLEASE HELP ME!!!! im waiting for someone right here to answer this.
work around your pipes its not that hard. just undo the 2 bolts that hold it in what i did is crawled under the car and held a wrnch on a bolt then my dad had the center council out and he turned screwws with a socket and an extention. but i ended up haven to get newer not rusted bolts
:::edit sry 4 spelling and grammer i tried to hurry 4 u :::
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atmosphere »</TD></TR><TR><TD CLASS="quote"> How do i remove the hook on the exuast from the rubber that holds on to it? its a 97 civic hx.</TD></TR></TABLE>
you pull it until it comes off .
put a little dab of greese on the exhaust hanger and it will slide right off. I had to unbolt my exhaust and take it off the hangers to install my b&m shifter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99teggsr »</TD></TR><TR><TD CLASS="quote">put a little dab of greese on the exhaust hanger and it will slide right off. I had to unbolt my exhaust and take it off the hangers to install my b&m shifter.</TD></TR></TABLE>
just use some wd-40
just use some wd-40
EtherEG93
10
Feb 5, 2007 05:49 PM
atmosphere
Aug 8, 2005 12:18 PM
